Introduction to Tables (aka., BB code)
Discussion in 'PriusChat Website Questions' started by bwilson4web, Jun 12, 2012.
  1. bwilson4web
    15,528
    It is not easy to document how to do table tags because if written in order, voila, you have a table:
    Column 1 Column 2 Column 3
    0 [tr][th]title 1[/th][th]title 2[/th][/tr][tr][td]row 1 col 1[/td][td]row 1 col 1[/td][/tr]
    Like this.
    Testing showed a leading blank before the trailing "]" disables some tag encoding:
    • [table ] - begins each table (remove the " " before the "]")
    • [th ] - begins each header column value
    • [/th] - ends each header column value (*)
      • [tr ] - begins each row
      • [td ] - begins each data column value
      • [/td] - ends each data column value (*)
      • [/tr] - ends each row (*)
    • [/table] - ends a table
    Since it is modal software, some sets of tags show up frequently:
    • [table ][th ] - begins each table and headers
    • [/th][th ] - separates each header column
    • [/th] - ends the header columns
      • [tr ][td ] - begins each data row
      • [/td][td ] - separates each data value in a table
      • [/td ][/tr] - ends each data row
    • [/table] - common end to table
    So take an excel table; export it to delimited text, and; use a common editor to substitute the pairs above as needed. Removed all ordinary <RETURN> or new line characters as these will show up as blank lines before the table.
    * - If you omit the closing tag of that mode (aka., TD, TH, TR) it appears to default close the previous tagged text and start new. This short-cut can almost cut the number of tags in half.
    GOOD LUCK!
    fuzzy1 and xs650 like this.
  2. Danny
    Danny Admin/Founder
    7,093
    2,108
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    You can also check out the BBCode Help page with details on how to create full featured tables using various cell and row codes.
    BB Codes | PriusChat
    dave77, fuzzy1 and bwilson4web like this.
  3. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    • Bob, thanks for doing another BBCode Table tutorial. Yours is easy to follow. One suggestion, the TH element is normally only used for the top or header row in a column, the TD element is normally used for the lower rows. It works either way though.
    • The BBCode help page Danny referenced is also one of the best ones I have seen online and worth a look. It has some BBCode elements I hadn't seen before.
    bwilson4web likes this.
  4. bwilson4web
    15,528
    BTW, it looks like we don't have to code the "[/<mode>]" tags. The next "[<mode>]" tag appears to close out the previous one. This cuts the number of tags needed nearly in half.
  5. Stev0
    7,201
    1,073
    Northampton, MA
    2022 Prius Prime
    Let's play Tic-Tac-Toe! I'll go first.
    Column 1
    0 [tr]
    1 [td]X[/td][td]. .[/td][td]. .[/td]
    2 [/tr]
    3 [tr]
    4 [td] .[/td][td].[/td][td].[/td]
    5 [/tr]
    6 [tr]
    7 [td] .[/td][td].[/td][td].[/td]
    8 [/tr]
    (OK, so this was just an excuse to experiment with tables)
  6. JamesCSmith
    JamesCSmith New Member
    59
    Tapatalk doesn't seem to support the table bb code. I just see all the codes and no tables. :(
  7. ProximalSuns
    ProximalSuns Senior Member
    1,877
    PNW
    Looks like you can just Copy/Paste a table. This from a OfficeMac Excel sheet. Is this what you were trying to do?
    One Two
    One Two
    One Two
  8. bwilson4web
    15,528
    And a good exercise that also show how the hard <RETURN> are displayed before the table is rendered. Also, you see the use of proportional spaced font.
    This is how I would approach it:
    Column 1
    0 [tr][td]X[/td][td].[/td][td].[/td][/tr][tr][td].[/td][td].[/td][td].[/td][/tr][tr][td].[/td][td].[/td][td].[/td][/tr]
    Trailing table text, use it or just see an extra blank line.
    Notice that the table text is using a mono spaced font.
    Stev0 likes this.
  9. bwilson4web
    15,528
    Huh? I can't figure this out.
    Perhaps some form of ASCII art?
    Line before the line with the tag:
    [pre]lead line
    This is the second line after the tag.
    The third line with two leading blanks.
    Final line with the tag.[/pre]
    Line after the line with the closing tag.
  10. ProximalSuns
    1,877
    PNW
    Hmm...stole the table info when it posted. Oh well.
    I guess easiest way is tell the non-coders in one's forum is to save the table as a PDF and post it.
