Invalid mode vs. Battery disconnect
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jaykh, Jul 7, 2018.
  1. Jaykh
    Jaykh New Member
    lOs angeles
    Hi there,
    1st of, thank you everyone for the wealth of information contributed by members.
    That said, I'm preparing for a brake lines bleed and caliper pins lube.
    Its a 2012 prius III with 45K socal miles.
    Aboit 10 days ago I noticed hesitation and little jolting right before coming to a complete stop (sometimes it's smooth).
    So my question is, should I put the car in invalid mode or disconnect the negative terminal for this job.
    Thank you
    52,350
    disconnect negative terminal.
  3. ASRDogman
    ASRDogman Senior Member
    7,792
    3,976
    Just keep the key fob at LEAST 20 feet from the car and you won't have a problem.
  4. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,520
    Bay Area, California
    2019 Prius Prime
  5. ASRDogman
    7,792
    3,976
    Can't bleed the rear brakes with the 12v battery disconnected.
    Keep the fob away until you completed the rear pad replacement and cleaning of the pins.
    Then you can do the bleeding per the videos. :)
  6. Kazper
    Kazper Junior Member
    Baltimore, MD
    Is it possible to bleed the front brakes with the battery connected?
    Also, in invalid mode, if you move the steering wheel will it knock it out of invalid mode?
    I've bleed many brakes before, but I'm deathly afraid of doing this due to the chance of receiving an error once all is said and done. I'd like some way to clear if needed. Suggestions welcome.
  7. ASRDogman
    7,792
    3,976
    Fronts are the same as any car.
    Rears you either need techstream, or have someone in the drivers seat, press the pedal while someone
    opens the bleeder. You can reset the code if you get one. Just don't let the fluid run out of the reservior.
    I'm not sure about the steering.
  8. ChapmanF
    18,499
    I think there are two different ways to get into "invalid mode", one using Techstream, one using a chicken dance.
    My experience is that asking for invalid mode through Techstream sets a C1451 code, which you also need Techstream to clear. But I never hear about that happening to people who went into invalid mode by way of the chicken dance. So that might be less overall trouble.
    If you don't have another person to hold the pedal while bleeding the rears, you can use an official Brake Rock.
    SFO, ndonart and CR94 like this.
  9. Kazper
    Baltimore, MD
    Thanks! Btw, I meant can you bleed the fronts with the battery disconnected. Wondering if I can get away with bleeding the fronts and then doing the whole techstream thing on only the backs. I'm guessing it will throw an error code. While I do have an OBD scanner, I don't think it is capable of clearing brake trouble codes: Ancel AD310.
  10. ASRDogman
    7,792
    3,976
    Yes, the front brake are normal power vacuumed assisted brakes as any car that is not a hybrid.
    The rears are electric.
    nutzaboutbolts has a video of how to do it without techstream.
    #10 ASRDogman, Apr 10, 2019
  11. Mendel Leisk
    41,860
    For pulling the calipers off the rotors: disconnect 12 volt neg cable. Leave it off till done, and push the brake pedal several times as a final step, before reconnecting.
    For brake fluid replacement: invalid mode. And read carefully the list of do's and don'ts. For example, don't turn a wheel while it's invalid mode, it'll kick you out of the mode.
    Definitely watch @NutzAboutBolts videos, on both topics.
    NutzAboutBolts likes this.
  12. ChapmanF
    18,499
    There is no vacuum assist in the Prius brake system anywhere. The power assist comes from brake fluid pumped into an accumulator to high (positive) pressure by an electric pump.
    CR94 likes this.
  13. ASRDogman
    7,792
    3,976
    That has been on my mind all day. I remember reading somewhere that the Prius is NOT vacuumed assisted.
    I was just too busy today to go check it out! Thanks!
    #13 ASRDogman, Apr 10, 2019
  14. CR94
    CR94 Senior Member
    2,740
    1,198
    Northwestern S.C.
    Thanks correcting that misinformation!
  15. Taxi/Limo
    Taxi/Limo Active Member
    524
    107
    How does that duplicate invalid mode and what is invalid mode anyway? Thanks
  16. Mendel Leisk
    41,860
    Invalid mode is explained in the first attachment in post #11. It's necessary to use techstream or invalid mode when bleeding the brakes. Either will do. Text from the attachment:
    Select ECB (Electronically Controlled Brake system) Invalid Mode.
    (1) Perform the procedure listed below in 1 minute.
    1. Turn the power switch on (IG) with park (P) selected and parking brake applied.
    2. Select N and then depress the brake pedal more than 8 times in 5 seconds.
    3. Push the P position switch and then depress the brake pedal more than 8 times in 5 seconds.
    4. Select N and then depress the brake pedal more than 8 times in 5 seconds.
    5. Push the P position switch.
    (2) Check that the brake warning light / yellow is blinking.
    Translation, a little more literal:
    1. Ensure parking brake is set, then within one minute:
    2. Push start button twice without foot on brake.
    3. Depress brake pedal and shift to N.
    4.Depress brake pedal 8 times within 5 seconds.
    5. Push park button.
    6. Depress brake pedal 8 times within 5 seconds.
    7. Depress brake pedal and shift to N.
    8. Depress brake pedal 8 times within 5 seconds.
    9. Push park button.
    10. Confirm invalid mode achieved by brake warning light blinking.
    #16 Mendel Leisk, Jan 24, 2020
    jerrymildred likes this.
  17. Taxi/Limo
    524
    107
    Thanks I will read up
    If you keep the key fob a good distance from the car when doing maintenance will this duplicate invalid mode?
  18. Mendel Leisk
    41,860
    Not a chance. :)
  19. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    In fact, am I assuming correctly that you'd need the fob in the car for the dance to work?
  20. ChapmanF
    18,499
    By the way, the front brakes are served by two separate hydraulic circuits, one for normal operation, one for fail safe. You'll notice if you follow the bleeding procedure in the manual that you do each front caliper twice. One time, it is like bleeding a conventional car, where you force fluid out by pumping the pedal. The other time, it is just like the rears, where you open the bleeder and the fluid flows right out under accumulator pressure. That happens because Techstream commands the right valves to open for that part of the sequence. If you are not following that sequence when you bleed the fronts, that entire separate hydraulic circuit never gets bled.
    Rebound likes this.
