Inverter collant pump fails at 70,000 miles,
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by subarutoo, Oct 17, 2008.
  1. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    :confused: Yesterday, I was bragging about my TOTALLY trouble free 06, @ 70,000 miles. Today, 70+ mph in the HOV lane, ding, all manner of warning lights, including the dreaded red triangle of death! I got off the freeway, everything looked OK, no leaks, smoke or other means of excitement. I drove less than 2 miles to Pasadena Toyota, and dropped the car off. The service rep just called, and said the inverter collant pump needs to be replaced. I said "that doesn't sound good ($$$$)". He daid the three sweetest words I know, "covered by warranty". Whew, I guess the extended warranty was worth something after all. I was thinking I wouldn't need it before it expired. Anybody else see inverter coolant pump failures about this mileage? It gave no visible signs of trouble, no leaks, smells, etc. Brag not, lest ye get the red triangle of death!
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    The inverter coolant pump is one of the weak points. Yours is not the first to fail.
    Tom
  3. nownow
    nownow Junior Member
    70
    Pinehurst NC
    Wouldn't that be covered under the 8/100,000 warranty? Inverter is part of the Hybrid system, and it can't run without the inveerter coolant pump.
    My understanding was that the extension was for all hybrid relared parts?
  4. Flying White Dutchman
    4,374
    313
    yes hyrbid warantry!!
  5. galaxee
    galaxee mostly benevolent
    9,810
    464
    MD
    yep, those fail from time to time, DH replaced a handful of them. it's covered under powertrain warranty- 5/60.
  6. radiovan
    radiovan Junior Member
    90 mi east of LA
    My inverter coolant pump quit just as I was accelerating to get on the freeway. The dealer said that the mechanical pump was leaking too. Since I'm way out of warranty with 135,000 miles on my 04 it cost $1,000 for parts and labor.
  7. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    is the 2004 much different then the 2007? according to my warranty booklet the inverter is good for 150,000 miles. if this also covers
    2004 i guess you were ripped off?
    maybe someone should post each year along with what tier it was
    for confused people like me
    california emissions control warranty
    parts list long term emission defect warranty
    air fuel metering system
    engine control computer (engine control module)
    throttle body
    air induction system
    intake manifold and intake air surge tank
    catalyst system
    catalytic converter (warm up three-way catalyst)
    exhaust front pipe
    exhaust manifold
    evaporative fuel system
    fuel tank
    hybrid system
    battery control computer
    generator
    hybrid battery
    hybrid control computer
    inverter with converter
    motor
    other parts used in above systems
    coolant heat storage tank
  8. rigormortis
    1,340
    26
    san jose, ca
    if the inverter with converter is covered but the coolant system that is connected to is not , man i would be upset. heh
  9. Flying White Dutchman
    4,374
    313
    what the hell 1000...... that pump only cost maybe 30 dollars
  10. Genoz World
    Genoz World ZEN-style living
    797
    La Canada
    inverter coolant pump.........................what is this? does it have to do with engine cooling? like a water pump on the older cars? where is it located and is it really just $30 dollars?
  11. SyCo
    SyCo Member
    207
    17
    Quebec
  12. Genoz World
    797
    La Canada
    SyCo, thanks for that. OK. now that i read the previous post, my remaining question would be this.....................
    it appears that there might be some fault in the pumps of the 2004/2005's...........HAS this problem been taken care of in the pumps of the late models? i have an 08. is the design of my pump different or the same? has it been updated/redesigned?
  13. TomSwift
    TomSwift Member
    37
    Louisville, KY
    2014 Nissan LEAF
    The TSB (linked in a post from Galaxee) shown in the thread referenced by SyCo (above) suggests that there were changes made to the pump in 2006. The TSB notes a couple of VINs that would be the point in model year 2006 where the change was made. So, as I understand it, 2006 Prius made after that VIN (cars with higher VINs) would have the redesigned part.
  14. Genoz World
    797
    La Canada
    TOMSWIFT - that's good. so the problem has been fixed..................<i assume?>
  15. N3FOL
    N3FOL Member
    891
    16
    Stewartstown, PA.
    Nice to know that the inverter pump is covered under the Hybrid warranty. I think my '08 has an 8 year 100K mile warranty. Checking under the hood, I think I will need to add inverter coolant (pink) pretty soon.
  16. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    N3FOL,
    What did you see? I would think that having to add inverter coolant in an '08
    would indicate a leak or very heavy duty use and should be cause for concern.
    I've got an '08 with 13K miles. Is there something beyond the recommended
    service items -- oil change, rotate tires -- that I've missed?
  17. galaxee
    9,810
    464
    MD
    the inverter coolant pump is not covered by the hybrid warranty. it is covered by the 5 year/60k mile powertrain warranty.
  18. qbee42
    18,058
    3,073
    Northern Michigan
    Low coolant for a 2008 is not normal, unless it started low.
    Tom
  19. subarutoo
    1,213
    23
    Chatsworth, CA
    Inverter pump followup: My car IS an early 06, Jan. 10 purchase. I received no recall notices, and it is the original pump. I wasn't clear just which warranty covered it, only glad that it was covered. For those in the LA/Pasadena area, Toyota of Pasadena fixed it with no apointment on a busy Friday morning, provided door to door shuttle service, and the car was done the same day, at the time they promised. I'm not a fan of dealer visits, but I was impressed with how thay handled my problem. BTW, I saw 6 or 7 new Prii, and even a used 07 on their lot, if anybody is tired of waiting lists, etc.
  20. furblog
    furblog New Member
    North Dakota
    2001 Prius
    Lol haha bragging eh? :D I wish that won't happen to me
