inverter coolant: 120k or 150k?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by letsgobobby, Aug 23, 2018.
  1. letsgobobby
    letsgobobby Junior Member
    32
    our 2012 has 135k miles now. we did the main coolant at 120k per maintenance schedule and dealer has been hounding us since then about inverter coolant as well. but I swore I saw somewhere that inverter coolant didn’t need done til 150k; however, now I can’t find that reference.
    can someone point me to the definitive source that says inverter coolant needs done at 150k? otherwise I’ll go with dealer rec and get it done now.
    hope to keep car another five years and 115k miles (250k total is our typical ownership cycle).
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    if it looks dirty replace it
  3. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    My owners manual had it at 150k;).
    That’s what I would do(y).
  4. 2012 Prius v wagon 3
    2012 Prius v wagon 3 Active Member
    281
    277
    Redwood City, California
    From the 2012 Warranty and Maintenance Guide, in a footnote:
    "Initial engine coolant replacement at 100,000 miles/120 months. Replace every 50,000 miles/60 months thereafter.
    Initial inverter coolant replacement at 150,000 miles/180 months. Replace every 50,000 miles/60 months thereafter."
    also in that document:
    "Drain the cooling system and refill with an ethylene-glycol type coolant"
    and
    "Your Toyota is equipped with Genuine Toyota Super Long-Life Coolant. The replacement intervals for engine coolant recommended in this booklet are based on replacement with Genuine Toyota Super Long-Life Coolant or similar high-quality non-silicate, non-amine, non-borate ethylene-glycol coolant with long-life hybrid organic acid technology (i.e., a combination of low phosphates and organic acids). If another type of ethylene-glycol coolant is used, replacement intervals may be different."
    #4 2012 Prius v wagon 3, Sep 26, 2019
    Robert Holt and CR94 like this.
  5. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    Take a looksee under the hood.
    Look at the coolant reservoir, should have a sticker on it mentioning it.
    Might be on the underside of the hood too.
  6. Mendel Leisk
    38,732
    FWIW, my Toyota Canada maintenance info make no distinction, says to replace both at 10 years or 160,000 kms (100,000 miles), whichever comes first. However, someone overlooked the sticker on the side of the inverter reservoir, which says to replace inverter coolant at 150,000 miles. Maybe the awkward footnote instruction in the US Warranty and Maintenance Booklet eluded them?
    I'll probably stick with changing both, at 10 years, which comes waaay ahead of the kms for me, lol.
    The Toyota Canada maintenance instructions have gone through some "interesting" transformations in the last few years too. For our 2010 model year, you get a very tricky-to-read summary of the maintenance, and it encompasses EVERY Toyota model. It almost drives you to create a chart.
    Around 2014 they changed to an excellent graph format, with services down the left column, and time/kms across the top row, and it's ONLY for the Prius.
    Then, maybe with the advent of 4th gen Prius, they completely stripped maintenance schedules from the Warranty and Maintenance Booklet, say nothing. All the schedules are in an awkward, event-by-event format, online only. And you can't see the full schedule, you need to enter months or kilometers, and it responds with what's needed. So if you've got about 8 hours, you could go through it, make a chart.
    @Tideland Prius have you noticed this?
    #6 Mendel Leisk, Sep 27, 2019
  7. Sharnold
    Sharnold Active Member
    379
    119
    Alabama
    I generally change them at 100k or if they are a salvaged vehicle at any milage or on an engine swap. I always flush out the system and make sure to carefully bleed the air out as not to get the inverter pump code P0A93
    Robert Holt and Mendel Leisk like this.
  8. letsgobobby
    32
    responding to my old thread, I did the inverter coolant at 140k miles and am doing it again today at 197k miles. this may be our last such service, hoping to buy an EV in about 18 months when the Prius is 11 years old and circa 230k miles.
    Raytheeagle and bisco like this.
