Inverter coolant drain plug gasket part #
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jimi1976, Aug 13, 2016.
  1. Jimi1976
    Jimi1976 Active Member
    242
    124
    Denver, CO
    My local dealer is awful (Autonation Toyota Arapahoe in Centennial,CO)....they are unable to locate a part # for inverter drain plug gasket. In fact...they tried telling me there isn't a drain plug at all
    Anyway....before I sift through dozens of part #'s online, I figured I would ask the group first.
    Thanks in advance!
  2. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    why not reuse the gasket
  3. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    As a wise man once said: it is better to have and not want than to want and not have." :)
    To the OP's question: I will be changing my coolant soon. Momentum Toyota of Fairfield,ca gave me the same response:mad:, but I was able to find the part number ( see the pic). I think both total were $5, so good piece of mind:).
    Good luck with your coolant change!
    FantasticalMagicOne and Jimi1976 like this.
  4. Jimi1976
    242
    124
    Denver, CO
    Reusing gaskets/washers is not good practice.....unless you're in a pinch....which I am not.
    #4 Jimi1976, Aug 13, 2016
    Raytheeagle likes this.
  5. Jimi1976
    242
    124
    Denver, CO
    Looks like a crush washer.....thank you!
