Inverter Coolant leak, followed by ABS and brake lights up
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by DongFeng, Jun 27, 2016.
  1. DongFeng
    DongFeng New Member
    Seattle
    I have a 2012 Prius Two (27,XXX miles) that suddenly had check engine light on. I stopped and discovered the leakage of inverter coolant from the inverter cooler/radiator, which was probably damaged by a small piece of rock on the highway. I called AAA tow truck that towed it home. After arriving home, I discovered that in addition to the check engine light, the ABS and brake lights are on now. I have ordered a new inverter cooler online and plan to replace it myself. The code error is P0C73.
    My questions are
    1. Why did the ABS and brake lights light up? Could it be a problem caused by inappropriate towing? The Prius was towed while in the Parking mode (hybrid on), with parking brake released, and the front wheels on the wheellock and the rear wheels on the ground.
    2. How do I know if my inverter coolant pump and inverter are still working?
    3. How do I change the inverter cooler? Any guides available for 2012 Prius.
    Thanks in advance to the experts out there.
  2. JC91006
    16,769
    8,567
    I suspect your 12v battery is drained, check voltage
  3. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    hope you didn't fry your inverter
  4. JC91006
    16,769
    8,567
    What is an inverter cooler? The radiator from the car does not cool the inverter, it's only for the engine.
  5. spiff72
    spiff72 Member
    184
    37
    West Michigan
    I could be wrong, but I think there is a separate radiator for the inverter coolant (similar to a transmission cooler).
    Also, just a thought regarding ABS and brake lights. When you say "hybrid on", are you stating that the vehicle was towed while in "Ready" mode? Could the system have been confused by the fact that the rear wheels were in motion while the vehicle was in Park?
  6. DongFeng
    DongFeng New Member
    Seattle
    Update, I have changed the inverter cooler (radiator) and after that all lights went off.
    Xterra72, Rebound and CR94 like this.
  7. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    That's right. The voltage inverter, which converts the DC power from the battery into AC power for the motor (and vice-versa) can get hot. So there is a separate radiator cooling system for this inverter. This is why, if you look under the hood of your Prius, you'll see two reservoirs with pink coolant.
  8. Rebound
    3,996
    2,644
    Portland, OR
    You're a stud!
    I hope you used the Toyota coolant (pink) when you refilled the coolant.
  9. DongFeng
    DongFeng New Member
    Seattle
    The problem now is, after AAA towed my car with rear wheels on the ground, the slip indicator light came on. I have disconnected the negative terminal of the 12V battery and left it disconnected for 30 minutes. After I turned on the car, the yellow slip indicator is still there. What can I do to make the light go away? BTW, The car can be driven without problems.
  10. JC91006
    16,769
    8,567
    Rear wheels on the ground is the correct way to tow, front wheels on the ground would be a problem
  11. tankyuong
    1,555
    661
    Central MO
    drive 3 blocks away it should turn off automatically
