inverter coolant level dropping no visable leak
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Beachbummm, Dec 20, 2014.
  1. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    just noticed my level is about an inch below the full mark, it was fine at the last oil change, no leaks that I can see....nothing on the ground, any ideas?
    also where can I buy the pink kool aid besides the dealer they said $32 a gallon ....can I just add water?
  2. jdenenberg
    jdenenberg EE Professor
    3,954
    1,952
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Buy the "Pink Cool Aid" (Toyota type super long life Coolant). A Gallon lasts a long time. Drain and refill your tranny fluid (Toyota type WS) and have a several ounce sample analyzed (I use R&G labs - about $25) to see if coolant is getting into the ATF (hopefully not).
    JeffD
    52,420
    how many miles on her?
  4. Beachbummm
    1,160
    392
    202,000 miles
  5. Patrick Wong
    18,210
    6,514
    Further, look at the inverter coolant pump and associated hoses, located behind the driver's headlight assembly, for any signs of a pinkish or whitish deposit which would be evidence of a coolant leak. Then, raise up the front of the car on jack stands. With a trouble light or flashlight, get under the car, and look very carefully at the transaxle, the coolant hoses, and the radiator for evidence of a leak.
    If the coolant level continues to decline after you've filled the inverter reservoir to the full mark, you will need to have the car evaluated at your local Toyota dealer.
  6. JC91006
    16,835
    8,605
    Mine did the same after the inverter pump recall. topped off and never happened again.
    Maybe toyota can help you top off on next visit. It's not worth buying a gallon to top off 6 oz
    #6 JC91006, Dec 21, 2014
  7. SageBrush
    SageBrush Senior Member
    11,627
    2,533
    Southwest Colorado
    Generic SLLC can be bought at Napa auto stores.
    Made by Zerex, it is called 'asian.' About ~$14 a gallon
  8. Beachbummm
    1,160
    392
    will do, thanks
    good, thanks
    the pump was changed months ago and I just noticed it was lower...Ill top it off with distilled water and check for leakage merged
  9. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    I Would change it.
    The dealer does not replace the fluid with the pump TSB.
    They just clamp the hoses off.
    Unlike engine coolant its a very easy DIY.
    And if in Florida the coolant takes a beating.
