Inverter Coolant Pump TIP!
Discussion in 'Gen 2 Prius Main Forum' started by drh20s, Jan 26, 2010.
  1. drh20s
    drh20s Junior Member
    55
    GA
    A reminder to anyone whose Prius II pulls a code that says the inverter coolant pump failed. If it is HOT weather and you use your A/C on "MAX" it's probably taxing the inverter.
    TRY THIS BEFORE CONSENTING TO SHOP WORK: Reset the code and let the A/C thermostat do its work: i.e., set them temp on 78-80 degrees and forget it. I have never had another code for the inverter pump after figuring this one out! :rockon:
  2. Patrick Wong
    18,200
    6,479
    Well, if the inverter coolant pump really has failed, then you're just ignoring the problem that the pump needs to be replaced. Although the inverter may not be heating up enough for the hybrid vehicle ECU to log a DTC, the inverter is still running hotter than it needs to.
    If you DIY, a replacement pump costs ~$90. If you must pay the dealer for this to be done you might be charged $300-$400. That's a reasonable investment to protect the inverter which costs $3.6K and the transaxle which costs $3.5K (not including labor required to install.)
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,999
    Fort Lee, NJ
    Replace the pump ASAP. Otherwise you are waiting for the inverter to die and that'll cost you thousands.
    So this is one warning before the inverter would die. Consider yourself lucky because for some they never got the error code.
  4. edthefox5
    edthefox5 Senior Member
    10,096
    4,806
    Clearwater, Florida
    No. Wrong assumption. RE: As far as taxing the inverter the inverter on my 07 runs very cool even in dead of summer. Living in Florida the car's AC has been on max cool all day everyday year round since I bought the car. I have a temp sensor on my Inverter and it does heat soak when you shut the car off after coming off a 90 degree day in stop and go and will shoot up briefly to say 120 F but for the most part will run around 90F on a super hot day. Very good cooling system. One day we had a 100 degree and stuck in stop and go. Traction battery was not happy but the Inverter was no problem. Never ever a code.
    When a Prius throws a code its not kidding.
    As stated your pump is probably bad and not pumping 100% and your cooking your inverter. You don't notice because its winter.
    You can prove it. Just buy a Laser Temp like this one:
    FLUKE 62 MINI IR THERMOMETER - eBay (item 110485319308 end time Jan-28-10 10:55:10 PST)
    and check out the chassis on the inverter for temp. It a very handy
    tool.
    Sears sells one for $20 too which worked good for me for about 2 years. Its good to get a baseline temp on things like this.
    BTW, have you ever had the Inverter coolant replaced?
  5. brick
    brick Active Member
    1,083
    78
    Upstate NY
    A working inverter pump should be able to keep the inverter at an acceptable temperature while blasting the A/C and driving around in the highest ambient temps you can ever expect to experience. The OP's pump really is dead or dying and needs to be replaced!
  6. Bob64
    1,540
    92
    Virginia
    If you DIY I'd get a repair manual and follow usbseawolf's guide on youtube to gain confidence:
    [ame=http://www.youtube.com/watch?v=-yf6eCeV4M8]YouTube - 2006 Prius Inverter Coolant Change[/ame]
  7. Frayadjacent
    Frayadjacent Resident Conservative
    375
    Austin, TX
    I'm a DIYer, so spending $90 on a pump is MUCH better of an option than a $3400 inverter. But then, my car will be under warranty for a few more years.
    With a vehicle like the Prius, I don't think I'd ignore codes and 'chance it'. Too many components are VERY expensive.
  8. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    211
    used to be "Glacial" Maine and now FL
    If I get an IR thermometer... where exactly do I aim it to get the best inverter temp read?
    Doing a long road trip to Florida this coming month and would probably be interesting to see temp values. Our '05 just went over 70K miles.
    And when should we change the inverter cooling fluid?
  9. drh20s
    55
    GA
    Well... another year gone by, now over 100,000 miles... no more codes. I did have the coolants replaced at 90,000 miles. I drive with my lights and driving lights on and am convinced running the a/c on 'max' in the summer taxes the cooling system -- not to mention, wastes energy and decreases mileage. 78 degrees is perfect and there has been no codes since I first started this thread almost a year ago... It'd be a shame for someone to waste $500 on a 'problem' that isn't!
  10. Patrick Wong
    18,200
    6,479
  11. aa1a
    aa1a Junior Member
    26
    CA
    I replaced the pump last spring. I got a check engine light and the dealer mis-diagnosed the problem as the battery cooling fan. Thanks to Patricks help, I figured out the pump was the problem and replaced it myself in about 50 min. When I bought the pump at the dealership I asked at the service department how much they would charge to replace it. They quoted me three hours. Funny how when I'm paying it's 3 hours and when Toyota is paying the bill it's 1.2 hours.
