Inverter coolant pump
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Crain, Dec 31, 2015.
  1. Crain
    Crain Junior Member
    32
    Muncy Creek,PA
    My check engine light is on and I think the inverter pump is shot. I have a some questions about how and when the pump is on. I have a mini vic on order and as soon as I get it hooked up I'll run for some codes. That is if I get it installed????
    1- With the car in "ready mode" and at start up (car cold) should the inverter coolant pump be running.
    2- With the car in "ready mode" Should I always see a water moving in the water reservoir.
    Thanks for your help Don
  2. Crain
    Crain Junior Member
    32
    Muncy Creek,PA
    I was searching "inverter coolant pump" and found the answer it should be running with the car "ready" Thanks Don
