Inverter Coolant Reservoir
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mseay92, Apr 17, 2016.
  1. mseay92
    mseay92 New Member
    Arkansas
    It appears that my 2nd Gen Prius (2009) has a significant leak in its Inverter Coolant Reservoir. Has anyone had this problem before? If so, was it an expensive fix?
    PriusPaddler likes this.
  2. Mendel Leisk
    40,574
    How fast is the level dropping?
  3. mseay92
    mseay92 New Member
    Arkansas
    It's like I never put anything in at all. It goes right to the ground
    PriusPaddler and Mendel Leisk like this.
  4. Patrick Wong
    18,200
    6,492
    Was the car in a front end accident that impacted the reservoir?
    Replacing it would not be an expensive fix unless you ignore the problem, which results in the inverter overheating and failing.
    The reservoir costs $34 plus shipping here:
    HYBRID COMPONENTS for 2009 Toyota Prius
    It is possible that a coolant hose has failed or is loose, instead of the inverter reservoir having a leak.
  5. mseay92
    mseay92 New Member
    Arkansas
    Yeah, it was in a front end accident. Everything seemed fine for a while, but the lights came on and I checked things out. The reservoir needs to be fully replaced, and that seems about it for now. Thanks for the info! I was searching high and low for a replacement part.
  6. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
  7. Mendel Leisk
    40,574
    Front end collision makes me think it's the radiator, or something connecting to it.
  8. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
  9. Mendel Leisk
    40,574
    Or maybe the aircraft carrier...
  10. FantasticalMagicOne
    FantasticalMagicOne Active Member
    264
    150
    Pennsylvania
  11. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    So the hose to the front will be cool fluid from the water pump, and the fitting to the bottom/side will bolt to the inverter.
    There are two structural bolts as well.
    PriusPaddler and Raytheeagle like this.
