Inverter coolant runs low
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Prius20, Jan 21, 2016.
  1. Prius20
    Prius20 New Member
    Mongolia
    Inverter coolant runs low and also regular coolant blows up. Do they use one line together? Everyday i have to fill the inverter. Any advice?
  2. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    They are on separate closed loop systems. Start looking for your leak(s) sooner than later. If you destroy your invertor due to lack of cooling you are not going to be a happy camper.
  3. xliderider
    xliderider Senior Member
    8,055
    3,222
    Honolulu, HI
    Check for damage to your radiators, usually from stones. Then check all hoses and clamps.
  4. Prius20
    Prius20 New Member
    Mongolia
    Thanks for the reply guys.
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    If you had the Inverter Coolant Pump replaced under recall that's the first place I would look. It's right behind the drivers side headlight. Get a flashlight. Then check the 2 hoses that enter and leave the transaxle. There the only 2 hoses so easy to see. Kinda hard to get under there though so may need to jack the car front up and block for safety.
