Inverter fluid change
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Darklandscape, Sep 12, 2022.
  1. Darklandscape
    Darklandscape Junior Member
    64
    Can I change the inverter fluid while only the front end of the car is lifted up?
  2. Noahdoge
    Noahdoge Active Member
    219
    148
    Mississippi
  3. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,511
    2,495
    Taylors, SC
    You'd need to overfill the the fluid at the fill hole until it starts to drip, lower the car to level with the pavement to get the level correct, raise it again and replace the fill plug.
  4. ChapmanF
    18,532
    Are you thinking of transmission fluid rather than inverter fluid?
  5. Mendel Leisk
    41,889
    @Darklandscape are you talking about coolant or transaxle fluid?
    Repair manual info for inverter coolant change:
  6. Georgina Rudkus
    3,511
    2,495
    Taylors, SC
    My mistake,
    When I did change the inverter fluid, I used a hole saw and cut a hole in the under cover under the drain plug. so that I could take it out and drain the inverter coolant without removing the whole undercover.
