Inverter Pump / 12v battery issues
Discussion in 'Newbie Forum' started by Mavis5mcc, Aug 25, 2021.
  1. Mavis5mcc
    Mavis5mcc New Member
    Oakland CA
    Hello Prius friends!
    My 2007 Prius’ inverter water pump failed about 2 months ago and my friend’s dad mistakenly diagnosed it as a bad 12v battery and replaced that. A couple weeks later, I had the codes read and discovered it was actually the inverter water pump that was failing and had that replaced (Professionally this time!) After driving fine for a couple weeks, I tried to turn the car on one morning and the battery was dead. I jumped and charged it and now the voltage is reading ~11.6v with headlights off and ~10.6v with headlights on. The car is not showing any codes!
    Clearly I need a new battery but I’m wondering if it is possible that my inverter is failing? Or if driving with the failing inverter water pump for a couple weeks killed my brand new battery… Is there a way to see if the inverter is bad?
    Thanks!!!
    49,500
    welcome!
    measure the voltage with the car on, should be around 14.if that is fine, it may just be a defective battery and under warranty.
    it has nothing to do with the inverter fluid pump. how did you charge it?
