Inverter Pump and Coolant Question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by paprius4030, Mar 4, 2010.
  1. paprius4030
    paprius4030 My first Prius
    2,077
    295
    Ormond Beach,Fl.
    Hi I'm looking for a little guidance. My 08 Pkg.2 Prius has a little over 97k on it and is running fine. We are planning to leave Sat. for Florida and will have just around 100k on it when we return so my extended warranty will be just about over. With all the talk lately about some inverter coolant pumps going out I was checking things and noticed that although I can hear the pump running when I look in the resivoir the coolant shakes a little and seems to be moving but not alot. How much is it supposed to be moving? The level is really full and color seems to be good but there is alot of white spots on the cap. looks like sulfur or something is coming out of the coolant. Does anybody else see this white stuff on the cap? I was planning on getting all the fliuds changed when I get back but now I'm wondering if I should get it checked out first? Thanks for your opinions.
  2. Patrick Wong
    18,199
    6,464
    white spots = aluminum oxide? That is not normal or good. I wonder if some clogging has formed within the inverter coolant passages.
    I'd encourage you to have the coolants replaced before your trip, if you can fit that into the schedule.
  3. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,994
    Fort Lee, NJ
    Sounds normal. I cleaned the white/pink stuffs. I made a video when I changed my coolant. Does your look like mine?
    [ame=http://www.youtube.com/watch?v=-yf6eCeV4M8]YouTube - 2006 Prius Inverter Coolant Change[/ame]
    2 people like this.
  4. paprius4030
    2,077
    295
    Ormond Beach,Fl.
    Thanks usbseawolf2000. That is a great vidieo you made. I didn,t eaxactly see your resivoir cap but it doesn seem to be how you described it. White/pink stuff. I guess it must be normal since you had it too. How much should the coolant move in the resivoir tank when the pump is running? Is there a thermostat or anything that regulates the flow depending on temp. or is it just on or off? Thanks.
  5. jreed
    jreed Member
    84
    71
    North Carolina
    I changed the coolant in my inverter a couple of weeks ago and was observing the fluid in the reservoir with the pump running. There was just a gentle motion of fluid, not turbulent or "boiling" looking at all.
  6. usbseawolf2000
    14,487
    2,994
    Fort Lee, NJ
    The pump is one speed so it is not variable.
    If I were to imagine on a boat in the coolant, the boat will be rocking and it will make me dizzy and probably throw up. It won't be like a storm or tsunami.
    2 people like this.
  7. paprius4030
    2,077
    295
    Ormond Beach,Fl.
    Thanks for the visual LOL:eek: I guess you'd feel like the tidy bowl man.
  8. NortTexSalv04Prius
    NortTexSalv04Prius Active Member
    915
    114
    Question
    If you have bad inverter. You have replaced one inverter pump and have a still had bad inverter. Now you replace inverter should you also possibly replace inverter pump again???
  9. Patrick Wong
    18,199
    6,464
    Well, you need to decide whether the inverter pump is functioning or not. Here are the indications that the pump is working:
    1) Make the car IG-ON (where instrument panel warning lights are on). Does the pump sound like an aquarium pump, without air bubbles? If yes, that is good.
    2) Look at the inverter coolant reservoir. Do you see fluid turbulence within when the pump is running? If yes, that is good.
    If the inverter pump is running, then there's no need to replace it.
  10. paprius4030
    2,077
    295
    Ormond Beach,Fl.
    Thanks Patrick, I followed your steps I found in another post to somebody. Seemed like the pump was running ok, but no matter now I traded it in on a 2010.
  11. miguelzottoyahoocom
    miguelzottoyahoocom New Member
    Mexico City
    Please help me out i have a prius 2004 in which runs good no problem on it, recently around 3 months i replace the P0A93 code the inverter pump the electric one in the fender with a new dealer one and 6 months earlier i replace the other pump down the fuse box the car. my car runs well but after all day using it long tris around town the vsc lights and red triangle lights up, i scan the car and no codes on it, then next day still the same and after driving it a little lights get off if i drive the car in short trips no problem but then after driving long ones lights come on again, then also get the car scan and the code P0A93 return but the part already replace recently, also i try to purge the system but the same problem can someone help me out on getting this solve????
    2004priusgal likes this.
  12. 2004priusgal
    2004priusgal Junior Member
    71
    new jersey
    Upgrade
    did you ever solve this issue?
