Inverter pump failure with no symptoms?
Discussion in 'Gen 2 Prius Technical Discussion' started by ProspectivePriusPeruser, Apr 30, 2020.
  1. ProspectivePriusPeruser
    ProspectivePriusPeruser Junior Member
    50
    Australia
    Hello all.
    I was a passenger in another Prius and noticed a whirring noise on startup that's absent from mine. I checked my inverter coolant reservoir for turbulence and noticed there's no movement at all in there.
    I don't have any warning lights and the car seems to be running perfectly fine. As far as I can remember mine has never made the noise that I'm now assuming is the pump, but I have driven it on some fairly warm days with no noticeable problems.
    Is it likely that my pump is shot and I've just gotten very lucky so far, and are there any other definitive ways to tell if there's a problem?
    Cheers.
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Try touching the pump with a finger or a rod (pencil, stick, etc), if you feel a vibration then it should be working.
  3. dolj
    dolj Senior Member
    8,558
    4,348
    Wellington, New Zealand
    Even if vibration indicates the pump is running, it still might not be working. If there is no discernible movement, this to me is a better indication of whether the pump is working or not.
    Yes and maybe not so much luck as a series of events that have worked in your favor. If there is not a great load on the inverter then it can run quite happily. The inverter coolant circulation pump (ICCP) failure is not monitored so it will not trigger a DTC, but if the inverter gets too hot that is what triggers a DTC (P0A93 and/or C1241, maybe others) to alert you to the situation. When this happens you will be pulling over and waiting at least 20 min for the inverter to cool down so you can go again and probably sticking to 45 MPH or less.
    You don't really want to run in this condition in the long term, because if the pump goes out in style and shorts out, it will blow the AM2 fuse and the dash and MFD will go out and you will be dead in the water until you isolate the ICCP and replace the AM2 fuse.
    Skibob likes this.
    52,390
    i don't recall a whirring noise on startup
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    This x2
    Try just pressing the power button 2x with your foot off the brake. The ICWP should run and the rest of the car will be quiet (as long as radio and fans are off). Makes it much easier to hear the pump motor running and makes makes the ripples more obvious since there wont be vibrations from any other source.
    Skibob and bisco like this.
  6. bisco
    52,390
    thanks, i will try that
  7. MathWeijzen
    MathWeijzen Junior Member
    74
    Netherlands
    I have the same issue....no movement at al...what to do next..replace pump?
  8. dolj
    dolj Senior Member
    8,558
    4,348
    Yes, that is what you need to do. It is not a particularly difficult job.
  9. MathWeijzen
    74
    Netherlands
    I find it odd though it runs all this time without any ¨problems¨.. no warning lights no DTC...no overheating...no blown AM2 fuse ...no nothing...how is that possible..is it slowly dying..?
  10. dolj
    dolj Senior Member
    8,558
    4,348
    If the inverter is not taxed too hard it can cope for quite a while, especially in colder climates. Additionally, for the AM2 fuse to blow, the pump has to short and it quite often doesn't. Your situation is the proverbial "sleeping giant", so as to speak.
    rogerdpack likes this.
  11. MathWeijzen
    74
    Netherlands
    the ¨sleeping giant¨...? To expect big problems if it fails comletely..? So best fix asap?
  12. dolj
    dolj Senior Member
    8,558
    4,348
    Een gezegde betekenis: a disaster waiting to happen.
  13. MathWeijzen
    74
    Netherlands
    i got it right...thanks for effort in dutch..the exact translation is ¨spreekwoordelijk..¨...meaning the same as ¨gezegde..¨
    thank u...
  14. MathWeijzen
    74
    Netherlands
    I just had a thought to double check the pump ,,,
    i attached a hose to the bleed screw off the transaxle (...inverter/converter)...and started try to bleed the system...so put car in READY mode..fluid started moving in the hose but never made it all the way into the reservoir...i guess pump is indeed bad..i also noticed a fair amount of air bubbles...so maybe someone never ever bleeded the system...where as the pump startedfailing..?
    so maybe this to is an alternative way to check your inverter coolant pump..
    me i am gonna order new pump and replace this asap.
    i attached picture of the hose going into the reservoir where u can clearly see where it stopped...
    I love Prius Chat....! thank u all!
    #14 MathWeijzen, Jan 28, 2021
  15. dolj
    dolj Senior Member
    8,558
    4,348
    Yes, that is a better word. Dank u wel.
    Just a question relating to your picture, would the coolant flow if the tubing did not loop so high above the reservoir opening? I was just wondering if maybe there is an airlock stopping the pump from actually pumping.
  16. MathWeijzen
    74
    Netherlands
    yeah I tried that already...it flows yes, but not very much fluid like a how do u say that piss trickle..?
    I try to shoot a vid...
  17. dolj
    dolj Senior Member
    8,558
    4,348
    I get your meaning. (y);) It was just a thought, but I'm glad you already tried it.
  18. MathWeijzen
    74
    Netherlands
    I do think there´s alot of air trapped in there...to a point that the flow just stops, still no momevement in reservoir whatsoever, here´s a short clip of bleeding and the flow coming out the hose...dont know if its visible... dont know if thats normal flow...
  19. TMR-JWAP
    6,404
    6,093
    Columbia, SC
    The flow rate through the bleed will also depend on how 'open' you make it. On another note, I personally think it doesn't hurt to treat that pump as a 75k mile maintenance replacement item, especially if you're able to DIY the replacement.
  20. MathWeijzen
    74
    Netherlands
    yeah of course...I ´open´ it few turns till it starts to flow.....and i already ordered a new pump..not OEM though...
