Inverter pump relay/fuse location
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Brandon316, Feb 3, 2019.
  1. Brandon316
    Brandon316 New Member
    Austin, TX
    I haven't been able to find a repair manual for my year and am trying to locate my inverter water pump relay and fuse. I've located the engine water pump and tested it but can anyone tell me which relay and fuse control the inverter pump?
    Thanks
  2. Elektroingenieur
    2,515
    3,259
    Three Touring
    The text and illustrations from the Repair Manual (more info) are available in the Chilton Library database, to which your local public library offers access at no charge.
    For the inverter water pump assembly, control and power supply are separate. Power (+BWP, blue wire) comes from the IGCT NO. 3 fuse in the Engine Room Junction Block Assembly. That fuse is fed, along with other loads, from the IGCT relay in the same place; there isn’t a relay dedicated to the inverter water pump. Ground (GND, white wire with black stripe) is via ground point A3. The control (drive) signal (SWP, green wire) comes from the Power Management Control ECU, to which a speed signal (NWP, pink wire) returns.
    See the System Circuit section of the Electrical Wiring Diagram for all the details; note that all four circuits go through the Ag1 wire-to-wire connector. In the Repair Manual, see the sample waveforms for IWP and NIWP in the Terminals of ECU pages for the Hybrid Control System and the information for diagnostic trouble codes P0C73-776 and P314A-828.
    CR94 and Brandon316 like this.
  3. Patrick Wong
    18,200
    6,474
    The 10A IGCT 3 provides 12V power to the inverter water pump. The IGCT relay provides power to that fuse.
    CR94, Brandon316 and m.wynn like this.
  4. Brandon316
    Austin, TX
    Thanks guys, I checked them out and they are both fine. Going to have to go further in figuring out what is wrong in another post.
  5. RajivR74
    RajivR74 Junior Member
    37
    Horn Lake, MS
    I'm trying to replace the inverter pump too. This is my first time working on a 3rd gen. I am a lot more familiar with my 2nd gen. Where is the inverter pump located on the 3rd gen? Any help is greatly appreciated. Thanks!
    Kmun likes this.
