Inverter pump replacement - alignment needed?
Discussion in 'Gen 2 Prius Main Forum' started by sktn77a, Dec 21, 2010.
  1. sktn77a
    sktn77a Member
    294
    NC
    Just had the inverter pump replaced under the recal. l Front page of the service receipt shows everything that was done - two parts and new coolant. On the second page, it said "Alignment". The shop is closed now so I can't call them to find out if they did one or what that means. Anybody had their wheels aligned as part of the inverter pump replacement?
  2. s3nfo
    s3nfo Member
    164
    24
    San Diego, Ca
    No, and they don't go anywhere near the suspension so can't imagine why you would need an alignment.
  3. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    Absolutely no need...
  4. sktn77a
    sktn77a Member
    294
    NC
    Thanks guys, didn't think so but seeing as they remove the front bumper to change a light bulb, who knows what they would get into when they replace the inverter pump!
    Everything is running well, though.
  5. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    58
    Fullerton CA
    I just did this pump replacement - afterwards I _DID_ need an alignment. My Prius, on the other hand, was just fine. ;-)
  6. s3nfo
    s3nfo Member
    164
    24
    San Diego, Ca
    Now that's just funny. Think I'll "get aligned" when I go home tonight, hmmm, break out some of the homebrew, or try to finish the scotch before the kids show up........
