Inverter pump ... Turn off Red Triangle
Discussion in 'Gen 2 Prius Technical Discussion' started by Whitestbeach, Oct 29, 2015.
  1. Whitestbeach
    Whitestbeach Junior Member
    Navarre Beach
    I had the red triangle pop up on my Prius. I codes I got P0A93 and P1121 I needed a new control valve and inverter water pump. I installed both the valve and the inverter pump filled it with new coolant and bled both systems.
    I went into maintenance mode so I could run the motor and bleed out all the water. My question is the red triangle is still on in my car when I start it up..
    Is there some way to clear the red triangle or does it just go away on its own? Not sure what to do.
    Nexus 6 ?
    #1 Whitestbeach, Oct 29, 2015
  2. JC91006
    16,673
    8,518
    How did you bleed the system? You are suppose to bleed out the "air" in the system, not the "water".
    If there are no problems, the red triangle should not be present. You can reset the car by disconnecting the 12v negative for a few seconds. Then reconnect and start the car. If the red triangle appears again, then you would need to read the codes and see why it's still on.
  3. Whitestbeach
    Navarre Beach
    Thank you very much I was just reading about unplugging the 12 Volt battery..
    Nexus 6 ?
  4. Whitestbeach
    Navarre Beach
    I did bleed the air out of the inverter system and the engine coolant system. I guess there are two of them. I watched about 10 different YouTube videos haha and use the bleeder valve and such I think I got all the air out
    Nexus 6 ?
  5. JC91006
    16,673
    8,518
    If you didn't touch the engine coolant system, there would be no need to bleed it. They are 2 separate systems
  6. Whitestbeach
    Navarre Beach
    I replaced both the inverter water pump and the control valve they both were bad. I didn't have any clamps to clamp the hose so I went ahead and drain the coolant and put new coolant in.
    Nexus 6 ?
  7. JC91006
    16,673
    8,518
    oh I see what you did. Yes then you would've need to bleed both sides. Did you drain and change the coolant?
  8. Whitestbeach
    Navarre Beach
    Yes
    Nexus 6 ?
  9. JC91006
    16,673
    8,518
    I've heard the hardest part to what you're doing.....is bleeding all the air out. You can try turning on the heat to max while you're bleeding, that always helps.
  10. Whitestbeach
    Navarre Beach
    Yeah it was a pain. I ended up going into maintenance mode and running the motor with the heater on and using the bleeder valve on the right side and it went pretty smooth. Just took a little while. Just trying to get the darn red triangle off I'm going to go out right now and unhook the battery for just a couple seconds. Thanks man
    Nexus 6 ?
  11. JC91006
    16,673
    8,518
    You might have to repeat the process of bleeding the air, sometimes it takes multiple times. Dealers often run into this problem.
    Whitestbeach likes this.
  12. Whitestbeach
    Navarre Beach
    Okay thanks
    Nexus 6 ?
  13. Whitestbeach
    Navarre Beach
    I thought I'd replied back and tell you what I did to solve my problem. I tried the battery trick and it didn't remove the triangle. So I hooked my obd2 backup and cleared the two codes and everything straightened up after that. I started it back up the red triangle is gone and my wife is driving it right now I will check the level of the coolant again when she gets back
    Nexus 6 ?
  14. lokareddy
    lokareddy Junior Member
    toronto
    Technology
    i have the same problem! i have not tried battery trick to remove red triangle light..!! i am buying code reader to remove the warning lights
