Inverter went out & bearing came apart in transmission - P0A7A Code
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Puppyburger, Feb 1, 2022.
  1. Puppyburger
    Puppyburger New Member
    Guys was needing some advice on the Prius that won’t go into gear. P0A7A Code
    Took it into Toyota and they’re saying the Inverter went out which caused the transmission to seize and it loosened a bearing.
    They’re quoting me $11,500 to fix, it’s a 2011 with 215k so that’s definitely out of the question.
    I’m curious if the inverter recall would cover the repairs possibly since they did say the inverter went out which most likely caused the transmission to stop which apparently made a bearing get loose as they hear grinding when they’re pushing it in and out of the shop.
    Any feedback much appreciated!
    49,431
    sorry to hear it!
    how many miles on her?
    what inverter recall?
  3. Puppyburger
    2011 Prius with 215,000 Miles
  4. PriusCamper
    PriusCamper Senior Member
    11,091
    4,514
    Pacific Northwest, USA
    Sounds like classic Stealership cluelessness... I bet if you take it to a hybrid specialist you'll get a totally different and way less costly diagnosis.
    jerrymildred and 2010moneypit? like this.
  5. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    I agree with Priuscamper.
    PriusCamper likes this.
  6. jerrymildred
    jerrymildred Senior Member
    11,508
    14,110
    Tampa, FL
    That diagnosis really smells fishy!!! I can't figure out how the inverter could make that transaxle seize. Dropping some washers or gravel into the fill hole could do it. But if the inverter quits, the motors just loose power and spin.
  7. PriusCamper
    11,091
    4,514
    Thanks for being my 2800th like! I was born on the 28th so that number means alot to me!
