Inverter - won’t go into ready mode
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by uniquepriusnamebub, Jun 14, 2019.
  1. uniquepriusnamebub
    uniquepriusnamebub New Member
    newport
    I recently changed the brakes on 2008 prius. I connected the two pins w a paper clip below the steering wheel to reset the codes and now it will not go into ready mode... only neutral and park...
    I was told to replace the inverter converter, but it worked before I connected those pins below the steering wheel... any ideas what i could have done or an easy way to at least restart it into ready mode again??
  2. Skibob
    Skibob Senior Member
    2,912
    1,505
    Northern California
    Try disconnecting the 12v battery for a few minutes then reconnect it and see what happens.
