Inverter
Discussion in 'Prius c Technical Discussion' started by HappyPaul, Apr 10, 2014.
  1. HappyPaul
    HappyPaul Junior Member
    26
    Minden, Ontario
    2019 Prius c
    Hi:
    The Inverter failed in my Brand new Prius C (Caused a "Check Hybrid System" error). The Service Advisor told me this is a very rare thing. They had to order a new one from California.
    What is the nature of an Inverter in a Prius? Is it a large part?
  2. xliderider
    xliderider Senior Member
    8,140
    3,276
    Honolulu, HI
    Along with the traction battery, motor generators, and internal combustion engine, the inverter is a major component of the Hybrid Synergy Drive system.
    It converts the high voltage current from the traction battery to lower voltage that powers the electric motors.
    It also converts the power recovered from the regenerative braking to high voltage to store in the traction battery.
    SCH-I535
    HappyPaul likes this.
  3. vincent1449p
    vincent1449p Active Member
    894
    332
    Singapore
    Hi xliderider,
    Actually it is from low voltage of traction battery to higher voltage of electric motors. The traction battery norminal voltage is 144V and the electric motors are from 144V up to 520V.
    Vincent
  4. PeterHaas
    PeterHaas Member
    152
    29
    Monterey Bay, CA
    [QUOTE="vincent1449p, post: 1991108, member: 1791]"
    [/QUOTE]
    "Step-up" inverters have been used for decades.
    The first likely use was in a Motorola "Works in a Drawer" television set, where the horizontal scanning frequency, 15,750 Hz, was used as the carrier frequency for the 115 volt, 60 Hz to many hundreds of volts conversion as part of this TV set's "transformerless" power supply.
    That was waaay back in the days of bipolar transistors, and the single-transistor "flyback" inverter.
    Today's applications usually employ three-phase ac as the output, and as much as 600 volts output, and today's inverters use IGBT devices, and, usually, "H-bridges".
    The higher output voltage results in conservation of copper, and the potential for higher mechanical power output per unit volume or per unit weight.
    Variable frequency output is but one advantage of this system, in a hybrid automobile.
    Indeed, MG1 and MG2 may be operated at different frequencies in the performance of their somewhat different mission functions.
    Andyprius1 likes this.
  5. Sonic_TH
    Sonic_TH Active Member
    573
    96
    Puerto Rico
    2016 Prius c
    Are there any updates on this?
  6. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    Very old thread.
  7. bisco
    51,937
    decrepit
  8. Sonic_TH
    573
    96
    Puerto Rico
    2016 Prius c
    That is such a new Prius C, or was, just to have the inverter to fail, i doubt it was the inverter at all.
