IPA claims global warming is natural
Discussion in 'Environmental Discussion' started by bwilson4web, Aug 28, 2017.
  1. bwilson4web
    15,511
    This is an advocacy story but it highlights why I prefer modern metrics, not proxy reconstructions.
    Source: Why the IPA's claim global warming is natural is 'junk science' | Graham Readfearn | Environment | The Guardian
    So when two staffers at Australia’s Institute of Public Affairs managed to get some “science” into a journal earlier this month, there was much delight in conservative media outlets, together with a distinct lack of any genuine scepticism.
    First, the pair used what’s known as proxy temperature records. These are estimates of past temperatures going back as far as 50AD that have been estimated from analysis of things such as tree rings and lake sediments.
    There are hundreds of these temperature records but the authors chose only six, and they don’t say why they chose the ones they did.
    They then fed these temperature records into several pieces of software and finally into another piece of software that performs a “machine learning” process. Out the other end comes a series of temperature reconstructions, from which Abbot and Marohasy make two claims.
    First, they claim that their resulting data shows the world would have warmed by almost as much as it already has, even if the industrial revolution had not happened and we had not added any extra greenhouse gases to the atmosphere.
    Second, they claim that if you were to double the amount of CO2 in the atmosphere then you would eventually see planet-wide warming of just 0.6C. Their estimate of this “equilibrium climate sensitivity” (ECS) is much lower than other studies (the UN’s Intergovernmental Panel on Climate Change says, for example, that studies show the likely range will be between 1.5C and 4C).
    Since the 1850s, modern instruments have built up a traceable record of temperatures with precise times and dates which proxy records are at best, coarse approximations. Berkley Earth has done an excellent job of culling the credible records from these sources to up current dates and times.
    Understand I like ice cores but they are limited in geography and some variability in time and date.
  2. Trollbait
    11,506
    Cancer, the flu, and ED are also natural. Let's stop doing anything about them.
    bwilson4web likes this.
  3. tochatihu
    tochatihu Senior Member
    9,045
    3,528
    Kunming Yunnan China
    2001 Prius
    Temperature variations are naturally seen even without [CO2] changes. They have been more rapid with [CO2] changes, regardless of provenance. Current +T co-occuring with +CO2 is rapid, but paleoproxies are not so certain that we can be very dramatic about them.
  4. JC91006
    16,475
    8,393
    Not sure anything can prevent global warming........so it's naturally going to happen and there's nothing we can do about it.
  5. Trollbait
    11,506
    We could slow it down if willing.
  6. thePimpsons
    thePimpsons New Member
    UK
    Bewilders me how so many people don't get this very simple point. Yes, it is a natural event, BUT, it's being greatly exacerbated by the actions of people on this planet.
    john1701a likes this.
