IPA question
Discussion in 'Gen 3 Prius Main Forum' started by Wooski, Aug 20, 2009.
  1. Wooski
    Wooski New Member
    241
    63
    London, UK
    Hi guys,
    I have a UK T-Spirit which is equipped with IPA. It parallel parks fine on the left hand side but when I try to use it on the right it just doesnt recognise the space - even driving pretty close to the other cars and sub 9mph. Should this feature be available on both side of the car?
    My car has an issue with the front bumper, which was removed and is being replaced. So it could just be that the sensor on my right hand side is not connected properly.
    Thanks.
  2. Fujisan
    Fujisan Blizzard Brigade #309
    126
    Warrington UK
    What's up with your bumper Wooski?
  3. nparker13
    nparker13 Member
    121
    CT
    Interesting. It definitely relies on sensors in the front when using the assisted parallel parking (pressing the button first then scoping out the spot), but it should be able to operate regardless based on the image the backup camera generates (and that you select). I'll have to give it a try (only use it for back in parking so far).
  4. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    I have a Prius V with AT and the IPA parks on either side of the street. It has a sonar sensor on both the left and right hand side of the front bumper for just this.
    I'm going to guess that one sensor is not functioning properly (not cpnnected properly, etc) after your bumper replacement.
  5. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
    Have you tried pressing the target parking position button to switch from left to right?
  6. Wooski
    Wooski New Member
    241
    63
    London, UK
    If you press the button again it jumps from parallel to rear parking mode.
    The problem with the bumper is because I ordered front parking sensors and they are not compatible with the IPA system. Something not realised until the 4 holes had been drilled in the bumper to fit the front kit. Apparently mine was not the only car damaged in this way. So I'm getting a new undrilled front bumper from Toyota. My guess is that the dealer's mechanics did not probably connect the right hand sensor back up properly when they re-fitted the damaged bumper. My new one is due next week hopefully.
  7. 32kcolors
    5,683
    952
    124
    Redondo Beach, CA
    I'm talking about a different button. You press it when you want to move the target parking position left or right. If you can confirm it only works on one side when touching this button, you have a faulty sensor.
  8. Tideland Prius
    16,072
    Yeah there's a separate button to switch it from left to right parallel parking which would be opposite to the button that switches to reverse parking.
  9. Wooski
    Wooski New Member
    241
    63
    London, UK
    What second button? I've just re-checked the manual - it doesn't mention a second button either. Strange.
  10. 32kcolors
    5,683
    952
    124
    Redondo Beach, CA
    This button
  11. Wooski
    Wooski New Member
    241
    63
    London, UK
    I see - its on the screen. I'll try again tonight. Thanks.
  12. Wooski
    Wooski New Member
    241
    63
    London, UK
    Mmmm. I only get access to that option to switch sides after it has measured a space on the left hand side. When I first select IPA mode it doesnt give me an option to switch sides. The problem is I live in a side street with parking on both sides and only enough room for a single one way lane of traffic up the middle. There are more spaces on the right hand side, so this is quite annoying for me. Especially as it works pretty well on the left.
  13. 32kcolors
    5,683
    952
    124
    Redondo Beach, CA
    Have you tried driving closer to the right side (less than 1 m from the cars) and see if it'll detect the right side first?
  14. Wooski
    Wooski New Member
    241
    63
    London, UK
    Yes I have. I suspect it's an issue with the sensor to be honest - I know the front bumper has been off the car and then re-fitted.
    What troubles me is no reference to sides in the manual. However it does show a picture clearly showing that both sides should be trying to detect other vehicles.
    Thanks for your help.
  15. Tideland Prius
    16,072
    Yeah it should detect either side without issue. We'll see if it's fixed after the new bumper is installed (Assuming they remember to attach the sensor wires)
