iPhone 5 Messaging Not Working
Discussion in 'Prius v Audio and Electronics' started by Vinoh, Sep 23, 2012.
  1. Vinoh
    Vinoh Junior Member
    San Jose, CA
    My new iPhone 5 seems to work great with Entunes on my V 5 ATP - faster and more stable connections than my iPhone 4 so far. However, I was disappointed to see that the Messaging functions (reading texts, emails, etc) don't work at all. I don't even see the button "Messaging" in Setup that is supposed to enable it. Very puzzling since the bluetooth information screen clearly show that the MAP bluetooth profile is now present in the phone.
    Anyone else try this yet? For those of you that have gotten this working on other phones, is there any other step needed to enable the Messaging functions?
    Thanks. --Dave
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    It works for only receiving for me if plugged in USB, over Bluetooth the screen doesn't show incoming messages.
  3. Air_Boss
    Air_Boss Senior Member
    3,942
    1,079
    New Yawk
    Disappointed to see no Entune app for Windows Phone... no streaming BT audio.
  4. MBRGuru
    MBRGuru Member
    255
    26
    See the other thread, but do you have notifications enabled for Messages? It's linked to that setting, so that may be why you aren't seeing the Messages button light up.
    Air_Boss - MS doesn't support Bluetooth SPP yet, that's why there's no Windows app.
  5. Air_Boss
    3,942
    1,079
    New Yawk
    Who needs SPP when A2DP suffices?
  6. MBRGuru
    MBRGuru Member
    255
    26
    A2DP is fine for audio, but you also need data transfer for the other apps.
  7. Air_Boss
    3,942
    1,079
    New Yawk
    Phone works and I can do without the other apps. The track info and timing passes thru. There's no rationale for the audio not passing thru.
  8. Vinoh
    Vinoh Junior Member
    San Jose, CA
    Good news. Messaging is now working, although I have no idea why. I see the Messaging Setup button and see and hear messages when they come in. However, I get an error when I try to use one of the canned responses; I think that's because the iPhone does not support this function.
    Also, Entunes reconnects automatically when I come back to the car, even if I don't launch it again. This is probably because the iPhone 5 has much more memory and so Entunes does not get purged as often.
    --Dave
  9. MBRGuru
    MBRGuru Member
    255
    26
    Correct, Apple disabled the reply capability, hence the error.
  10. Air_Boss
    3,942
    1,079
    New Yawk
    In fact, text-to-audio text messaging and voice reply work via BT. Seems the only things INOP are streaming audio via BT and ability to connect/internet access.
  11. Quentin
    Quentin Member
    335
    88
    West Virginia
    I don't see anywhere in Entune on my ATP v 5 to set up messaging. Is that in some other menu on the radio?
  12. Air_Boss
    3,942
    1,079
    New Yawk
    Just connect the phone (Nokia Lumia 900 WP7.5 phone, in my case) via BT.
    Incoming text messages are alerted then annunciated via text-to-voice, followed by the option to "reply" or "ignore" via a voice-to-text option.
  13. Quentin
    Quentin Member
    335
    88
    West Virginia
    I am connected via Bluetooth. The Entune system works flawlessly. Maybe I need to adjust a setting in my Bluetooth connection.
  14. MBRGuru
    MBRGuru Member
    255
    26
    Do you have "Show Notifications" enabled on the phone? If so, try checking the Messaging Settings. It's in the Phone Settings in the Setup Menu from memory.
  15. Quentin
    Quentin Member
    335
    88
    West Virginia
    It was actually under the Bluetooth connections. I had to turn notifications on under the connection that is specific for my Prius.
  16. Air_Boss
    3,942
    1,079
    New Yawk
    Now BT Stereo Audio and streaming music from the WinPhone work. Marvelous!
    Why now and not before? 1./ No idea and 2./ Who cares!
    Only remaining persistent fail is Internet; will have to debug an AT&T Wireless DUN connection due to lack of Entune on a WinPhone.
  17. Skilene
    Skilene New Member
    Dave,
    I'm experiencing the same issue with the Prius and iPhone 5. Were you able to get emails to work or just text messages? Are you connecting through Bluetooth or USB?
  18. Vinoh
    Vinoh Junior Member
    San Jose, CA
    Just text messages. I use Bluetooth. I think ios 7 may add the capability for more kinds of notifications but Toyota would have to upgrade the firmware to enable them. I doubt that they will though.
    Skilene likes this.
  19. Zephyr7
    Zephyr7 Member
    301
    28
    I don't think Apple is pushing emails over BT, emails over bluetooth already works on ancient Blackberry devices.
    even some Android maker got it working somewhat. Bluetooth did spec it out.
  20. MBRGuru
    MBRGuru Member
    255
    26
    There's nothing new for MAP in iOS 7. SMS/iMessage incoming only. Still no Reply support. No E-Mail notifications.
