iPhone 5 won't connect through USB
Discussion in 'Gen 3 Prius Audio and Electronics' started by gak27, Oct 30, 2015.
  1. gak27
    gak27 Prius, Take Two
    117
    Akron, OH
    Greetings all!
    2013 Prius Four w/ Deluxe Solar Package. First time plugging my iPhone 5 into USB port since getting the car. Phone charges but is not showing as available via USB. It does connect via Bluetooth with no issues.
    Any ideas? Thanks!
    Greg
  2. mrbigh
    3,686
    699
    Long Island, NY
    I WOULD TRY WITH THE ORIGINAL USB IPHONE CABLE OR TRY A SECONDARY WELL KNOWN WORKING CABLE
  3. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    I had some Bluetooth issues with Xmas lights due to the lights app had a bug with iOS9 update.
  4. BZzap!
    BZzap! Senior Member
    1,607
    877
    Push AUDIO button> touch Source on screen> touch ALL on screen> this should show all sources. There is a USB window with all source Windows. Then plug in your phone to the USB cable. This should highlight the USB window to indicate connect. If the USB window doesn't highlight, then I would suspect a bad cable. If it does highlight then you need to fiddle with your iPhone settings.
