iPhone and streaming music via bluetooth
Discussion in 'Gen 3 Prius Audio and Electronics' started by jsimon77, Jul 6, 2010.
  1. jsimon77
    jsimon77 New Member
    Los Angels
    I have the new iPhone 4g. I got the streaming to work on my new Prius with navi but none of the buttons work. I can't skip songs, or go back...I just get the auido.
    Am I doing something wrong? Is this an iPhone issue? I'm interested to know other peoples experiences.
  2. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    You'll probably get a better response in the correct sub-forum. ;)
  3. TonyPSchaefer
    14,816
    2,496
    66
    Far-North Chicagoland
    I moved to the Technical Forum. Hopefully you'll get replies.
  4. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    All you get is play and pause buttons on the nav screen. Apple doesn't fully support the latest and greatest bluetooth profile that would give more control.
  5. web1b
    web1b Active Member
    817
    52
    The absolute latest and greatest version of bluetooth displays track names too, so Apple is 2 versions behind in bluetooth support since they don't even support track skipping.
    You are better off using the USB connection if you want to control songs from an iPhone.
  6. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    I suggest a quick comment to Apple regarding this. I have been doing so with every new release of iOS. Apple - iPhone - Feedback
  7. zdenok
    zdenok Junior Member
    57
    Bratislava, Slovakia
    Track skipping is possible also under ios4 using steering wheel buttons and buttons on the radio itself.
    iPhone ?
    Zdenok
  8. rstark18
    rstark18 Member
    442
    75
    Los Angeles
    iOS 5 finally is up to date with their Bluetooth stack. You can now see track info, artist name, etc.
  9. trentofdestiny
    trentofdestiny Master Finagler
    1,104
    225
    Harrisburg, PA
    Really? Sweet! I hadn't tried it on iOS 5...guess I will be switching back to using BT. I got better sound from USB (Bluetooth sounded good on its own but sounded "flat" compared with USB under iOS 4).
  10. Tideland Prius
    16,017
    Yep.
    Song title, Album, Artist.
    Actual info, not like the CD/USB stuff that gives filename, folder, artist.
  11. Notjcb
    Notjcb New Member
    ma
    Do you need Navi to do this?
  12. stream
    2,977
    452
    Long Island, NY
    In the US, yes.
  13. bighouse
    bighouse Active Member
    822
    126
    Guerneville, CA
    Really???!!!?? I have the new 4S and I enjoy hearing Siri speak through my Navi system- but I've yet to stream bluetooth again with the new 4S. I'll look into it tomorrow.
    Has any changes been made to the USB connection with the new OS? It was once so slow and convoluted that I gave up trying to use the USB iPod adapter with my 3GS.
  14. cproaudio
    cproaudio Speedlock Overrider
    2,401
    758
    CA
    You have to pair the audio media player separately from the phone. Just goto the audio setting and pair it from there.
  15. bighouse
    822
    126
    Guerneville, CA
    OP: You CAN play different tracks by using the SEEK and TRACK buttons on the Navi unit itself (Up and Down) to move between songs! There's no touch screen button to do it, but you CAN do it with the manual analog buttons.
    It's SO nice to be able to finally see the audio bluetooth information on the screen. I'm really glad to see this change! I'm now going to have to rehook up my 4S to the USB port in the console to see if there are any changes in the USB interface as well. I know that with my 3G the interface was so slow it was utterly useless and I opted instead to just control my music via bluetooth and my built-in iPod player back then.
    You can also use the "V" "^" buttons on your steering wheel as well. By holding the buttons down longer than a quick hit you can skip to a different album too according to the owner's manual.
