iPhone and streaming music via bluetooth
Discussion in 'Gen 2 Prius Technical Discussion' started by Fireyshamrock, Oct 18, 2011.
  1. Fireyshamrock
    Fireyshamrock New Member
    VA
    I have a 2005 Prius and currently play my music through the tape deck via my iPhone 4. I was driving a few days ago and saw in the bottom right hand of the screen a square with a little triangle in it. After clicking it I had the option to play through the bluetooth connection. I was VERY excited as less cables would be great & I didn't think I had the option. I got in the car the next day and the option isnt there anymore, I don't know how it happened, but I know it did so there HAS to be a way to do it and I am just the idiot who can't figure it out. Any ideas?
  2. Fireyshamrock
    VA
    Note - I have an iPhone4 with iOS5. I have the nav screen and all that jazz on the prius as well. I am just at a loss for why it randomly just came on and I can't recreate it to happen again.
  3. Fireyshamrock
    VA
    ........Buuuuueeeellller?
  4. jpadc
    jpadc Type before I think too often
    343
    34
    Indianapolis and Northern Wisconsin
    music streaming is not supported by the bluetooth protocols on any G2 model of the Prius. So unless your radio has been replaced with an aftermarket unit, it can not stream music wirelessly over bluetooth.
  5. djasonw
    djasonw Active Member
    949
    115
    Coconut Creek, FL
    I have an IP4 too and a 2004 Prius with B/T. I was able to get the NAV voice from my iPhone to play over the bluetooth. Even tho my car has nav, I sometimes use the TomTom app in areas where there are new subdivisions (I have a 2008 data disk). Anyhow, I can't figure out how it does that, but it does. Also, I can hear my voice mails thru the b/T.
  6. J.Wilkie
    J.Wilkie 80 Mile Daily Commute
    157
    Behind The Orange Curtain
    I hear my Voicemails through bluetooth also. I have a IP4 too.
  7. LIPriusFreak
    LIPriusFreak Can I haz JDM?
    449
    34
    Long Island, NY
    if your 2004 doesn't have the aux-in port in console, then the only way is to replace the HU or keep using the cassette adapter
    I can tell you I wish i had a cassette adapter over the annoying crackling aux-in input in my console
  8. cwerdna
    cwerdna Senior Member
    12,544
    2,122
    SF Bay Area, CA
    Crackling or is it more of an electrical noise that's coordinated w/various vehicle activities (e.g. pressing on the brake)? When? Always or only when your device is being powered?
  9. LIPriusFreak
    449
    34
    Long Island, NY
    I am aware of the noise you speak of ( electrical ground playing thru speakers) but that's not what I was referring to. When my iPhone 4s or my old iPhone 4 is connected via aux in I get a crackling when it's playing and sometimes it goes also monotone like a channel fades out. Only goes back to Normal when I open console and fiddle with auxin wire ( it's not the wire because this is the third wire that does it). This is annoying when your listening to a great track doing 80mph down te highway and all of a sudden the track goes out? I mean really lol
  10. Rest
    Rest Active Member
    1,210
    51
    CA
    Just not possible on the 2nd Gen Prius, unless you have an aftermarket radio.
  11. DaBlick
    DaBlick New Member
    Nanuet, New York
    If you are charging your iPhone when this noise is happening try unifying the charger to see if the noise goes away. For me, it always does. Sometimes I find that if I unplug the charger and then plug it back the crackling sound does NOT come back. So it is sometimes possible to listen and charge wo the noise.
  12. PriusGuy32
    1,411
    506
    Harrison Township, Michigan
    Well, thats not entirely true... a few cars ago I had my mp3 player hooked up to play through the cassette player via one of these:
    However what you meant to say is it is impossible to play music streaming through bluetooth on a Gen2. Right?
  13. Kurzweil
    Kurzweil Member
    109
    34
    Atlanta
    I've played music through my 2004 Bluetooth. It was not a pleasant experience. The frequency response is severely limited and only suitable for a phone call. The iPhone music was a voice recording but the quality of the recording was high. Cassette adapter is the way to go on this model.
    PriusGuy32 likes this.
  14. Bradkb
    Bradkb Junior Member
    Kent, UK
    I have a parrot bluetooth kit that supports music streaming, and regularly stream from my iphone5 to the car, works great
  15. Kurzweil
    Kurzweil Member
    109
    34
    Atlanta
    So perhaps my experience reflects limitations with the factory CD/cassette/bluetooth system.
  16. Pandalover
    Pandalover Junior Member
    82
    UK
