iPod into 2004 Prius
Discussion in 'Gen 2 Prius Main Forum' started by invisiblegun, Oct 3, 2006.
  1. invisiblegun
    invisiblegun New Member
    Hey there, sorry if this question is repetitious in any way, I tried scanning all the forums for the answer but so far it seems to me very inconclusive and mighty specific.
    I am wondering if there is anyway besides a tape adapter or FM transmitter that I can hook up my iPod to my 2004 Prius. It is one with an 'everything' package (not sure the #) so it has the navigation, bluetooth as well as 6-CD changer.
    So basically, is there anything I can do to put an iPod in my car--I don't care if I can't control it using the steering wheel controls. I read that there might be a way to do it but that it would disable the functionality of my 6-cd changer?
    Thanks very much for any help, I've been trying to do this for awhile now...
  2. aaf709
    3,862
    2022 Prius Prime
    There's a couple of devices, one is by DICE (about $159) and the other by VAIS (about $299). Both will work with your 6-cd changer and will allow controlling the iPod on with the steering wheel and MFD.
  3. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
  4. invisiblegun
    Thanks very much for the replies.
    Does the DICE one work through the radio (for slightly lesser sound quality) or directly into the stereo (for better quality)? Anyone know how easy it is to install?
  5. Tideland Prius
    16,151
    It's plugged into the radio. Both are fairly easy to install. Just remove the lower glovebox and the vent to the right of the stereo (looking at the radio, facing forward) and if you wish, that box behind it but I couldn't remove the screw so I just wiggled my hand between the box and the radio.
  6. eagle33199
    5,122
    268
    2015 Prius v wagon
    both the Vais and the Dice opperate in basically the same manor. They both plug into the back of the radio/MFD, and then into the iPod. they both give you steering wheel and MFD controls of the iPod. they poth provide sound at the same quality level as the iPod lineout (minus any quality decreases inherant in the system that you would get from other sources, like radio or CD).
  7. aaf709
    3,862
    2022 Prius Prime
    Also both have an AUX input, where you can connect something like a Sirrus or XM radio (unless you've got a built-in which plugs into the cable that attaches to the radio).
  8. heyjude421
    heyjude421 thread bumper
    36
    Sorry to bump this old thread, but I have a 2004 that does not have a CD changer - can I still use the DICE?
  9. Bear68
    Bear68 Member
    373
    72
    West Palm Beach, FLA
    I installed a DICE unit for a customer in a Prius with the basic stereo unit. It worked Very well and actually impressed me (something which is NOT easy to do with aftermarket devices) I thought the functionality and control were easy to learn and worked very well giving the user lots of information on the Muti Function Dispaly unit and integrating very nicely with an iPod. I have not had opportunity to test with other types of MP3 players, since the customer had only an iPod. When the day comes that I finally give up my 97 Tacoma, my next car will be a Prius and the DICE unit will be one of the very few aftermarket add ons I will consider.
    (this coming from a true Toyota Purist, I prefer to see Toyotas left just the way they were designed, Makes it easier to fix 'em)
  10. Tideland Prius
    16,151
    Welcome to PriusChat!
    Yes it works. you can contact vagabond here on PC, he's a DICE rep.
    Another Prius technician. Welcome! Perhaps you can put that title under your name (where it currently says Senior Member")
  11. HighBreed
    HighBreed Member
    113
    Los Angeles/Orange Counties
    They both seem equal. Why would anyone buy the much more expensive vaistech? What did I miss?:eek:
  12. Amalenz
    Amalenz New Member
    New Orleans
    Any preference over the Neo Pro Link (for 2004 Prius on icarkits.com), VAIS or DICE?
    (I'm still catching up my car to my nano).
  13. bulletprooffool
    bulletprooffool Junior Member
    37
    London, UK
    I am in the UK, have an 04 T Spirit, 6 Disc Changer etc. I have a Zune, not an iPod so am only really looking for aux in.
    Apprently there is a way to plumb into the CD changer without buying one of these pricy options? any idea? I do not expect to be able to use the on screen display or anything, simply want to b able to play my MP3 Player without a cassette adapter or an fm transmitter!
  14. bulletprooffool
    37
    London, UK
    The cassette I got is rubbish - the tape keeps 'turning over' - I think the bits that turn do not turen as easily as they should, so each time the tape gets 'turned over' I get an interuption . . any ideas on plumbing Aux straight into the CD Changer? i have had a look on here, but can find no conclusive direction :(
  15. bulletprooffool
    37
    London, UK
    I guess this can't be done? Thanks anyway to those who looked :(
  16. SW03ES
    SW03ES Senior Member
    2,480
    176
    Gaithersburg, MD
    I have the Vais unit in the Lexus, we'll get one for the Prius too. Its awesome! I have the iPod unit that controls the iPod and the Aux in for the Sirius radio I already had in the armrest compartment. Works beautifully. The installer tha put it in says its the best aftermarket unit he's ever seen.
    I did a LOT of research into DICE vs Vais. The Vais seems to be more reliable and their support is better, and the unit even when you hold is is much more solid and OEM looking than the DICE. Since I was having it installed into the console professionally, I didn't want it to fail and have to have the whole car taken apart again to get to it.
    We're going to get the Sirius with the AUX-in for the iPod in the Prius.
