Ipod - usb vs aux
Discussion in 'Gen 3 Prius Audio and Electronics' started by Linda513, May 4, 2012.
  1. Linda513
    Linda513 Junior Member
    24
    us
    I am currently using the aux plug to plug my ipod into the Prius, because I have the type of aux cable that also has a charging cable which I plug into the charger in the console, that way the battery on the ipod never runs out.
    Are there any advantages to plugging in my ipod with a usb cable instead of the aux cable? And will this keep my ipod charged as well?
    Linda
  2. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    The USB will keep your iPod charged. It also gives you the function of changing tracks and looking through your music with your display unit. I would think its more convenient. That way you can just keep your Ipod tucked away in the compartment instead of having it occupy one of the cup holders.
  3. Linda513
    24
    us
    Ah, yes that does seem like a big advantage. I didn't know that, thank you!
  4. Big Steve
    Big Steve ramblin wreck
    402
    39
    Richmond VA
    I have my iPod connected to USB, and keep it the console box. It keeps charged. My iPhone is hooked up BT. This means no Entune, but not a big loss I think. On a long trip I might switch to USB for phone to charge, but it really doesn't need it much because it is mostly idle.
    The ipos USB functions are very good.
  5. Linda513
    24
    us
    I tried the usb connection, but I can't fast forward or rewind when listening. I've been listening to mp3's of lectures, and this is a real problem. And it seems that all control of the ipod is lost to the car system. I suppose this method is fine for music, but definitely not lectures or books. Back to the aux for me.
  6. Big Steve
    402
    39
    Richmond VA
    I think fast forward/rewind is limited to skipping forward or back tracks, so probably a problem with lectures, books, podcasts.
  7. Rebound
    Rebound Senior Member
    3,972
    2,627
    Portland, OR
    An iPhone 4 needs 5 volts, 1amp in order to charge. The USB connection in Prius (like most USB ports) is 5 volt 1/2 amp, which will charge slowly, but not if the phone is in use. When I drove from LA to SF, using the phone's GPS and Bluetooth most of the way, the battery depleted as I drove. There are 12v, 1A car chargers designed for iPhone which will charge the phone at full speed.
    wstt likes this.
  8. markabele
    5,084
    1,782
    Nebraska
    I thought if you hold down on the forward/backward buttons that it will move through the same track.
