ipodinterface
Discussion in 'Gen 2 Prius Audio and Electronics' started by jfarmakis, Sep 29, 2008.
  1. jfarmakis
    jfarmakis New Member
    ohio
    I've had my 08 Prius for 3 weeks now and trying to figure out how to hook up my Ipod (car came w/pkg 5 and 6 disc cd onn radio).
    Any help is appreciated.
    Jim
  2. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    You can check the Priuschat Shop for parts that will allow you to hook you iPod into where the SAT radio would go or
    Go to any electronics store, buy a short AUX cable, for $5 or so. Inside the center console, there is a little flap with AUX written on it, open it and there will be a green hole there. Plug the cable in, plug the other end into your iPod and switch to AUX on the dash. Should be good to go, only thing is, you have to change the songs through the iPod wheel.
  3. Jack66
    Jack66 Kinda Jovial Member
    766
    Stafford, Virginia
    Simplest way is to buy a male-male connector from Radioshack or the equivalent and connect the iPod to the AUX jack in the center console. You can buy a connector that plugs into the iPod earphone plug or one that plugs into the digital interface (where you sync to iTunes). You have to put your stereo in AUX mode. Use the search function and you will find about a hundred threads on the topic - to include more advanced/integrated options that display song information on the MFD or allow you to use the steering wheel controls.
  4. Jack66
    766
    Stafford, Virginia
  5. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    quick tip: if you use the connection method where you use the male to male connector through the headphone output on the iPod you will have to adjust the volume on the iPod to at least 3/4 of the volume for a good clean signal.
  6. zenMachine
    zenMachine Just another Onionhead
    3,355
    300
    This may or may not be obvious, but be sure to get a 3.5mm-3.5mm cable that is Stereo. Some are mono only.
  7. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    "i am a total newbie & and i went to a discount/outlet store how do i know if the 3.55mm to 3.55mm cable is stereo or not"
    on the end of the aux cable there is a black ring.
    one black ring is mono
    two black rings are stereo
  8. morpheusx
    1,555
    81
    Akron, OH
    good tips.
  9. rigormortis
    1,340
    26
    san jose, ca
    three black rings = this is a nokia cell phone headset cable, speaker, microphone, switch to hang up phone
  10. zenMachine
    3,355
    300
    Some AV 3.5mm cables also have three rings, one for video, the other two for stereo audio. Usually this type has three RCA jacks on the other end though. I have yet to see a 3.5mm-3.5mm AV cable.
    When in doubt, read the package. It should say Stereo or Mono.
    Oh, and for iPod, I think the AV 3.5mm cable is non-standard. So if you want to also output video you'll need to get an Apple cable to be sure.
  11. katiewin
    katiewin New Member
    23
    Bristol, VA
    Does someone know if I have a Bluetooth iPod Nano Adapter will it work with the bluetooth in my pkg 6 Prius when it arrives?
  12. rigormortis
    1,340
    26
    san jose, ca
    that won't work, the prius bluetooth is just for the telephone
