Is 12.3v at the battery terminals low enough to cause trouble?(?Yes?)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Salvage09, Sep 11, 2015.
  1. Salvage09
    Salvage09 Junior Member
    38
    Pasadena CA
    My daughter across the country just bought an 05 Prius, drove it 2-3 hours home and two days later it died w the red triangle, ABS, and battery symbol lit.
    Pushing start button => can only go from Park-Neutral. Same after removing 12v ground from battery & replacing, but 12v.battery at terminals, car OFF reads 12.3v which is about half charge, for what should be a fully charged battery. Is that low enough to cause problems (so it's the 12v, not the hybrid battery?)
    From other places on PC, I get
    12 volt battery:
    Open voltage at 68 °F (20 °C):
    12.6 ⎯ 12.8 V Fully charged
    12.2 ⎯ 12.4 V Half charged
    11.5 ⎯ 11.9 V Discharged
    I know for sure that <12v is DEAD, but wasn't completely sure about 12.3.
    I think I answered my own question. If it only hits 50% when it should be fully charged, it's likely enough for the 12v battery to be the problem that it's worth replacing it first, especially since the car is throwing the ABS code as well.
    I'd still appreciate other opinions. What do the experts think?
    Thanks!!
    ANSWER!!!
    Yes, 12.3v at the battery is TOO LOW!! Replaced the 12 v battery and everything resolved immediately!
    #1 Salvage09, Sep 11, 2015
  2. JC91006
    16,674
    8,519
    no, the 12v is not the problem. You need to get a code reader to see what's wrong with it.
    Just having purchased the car, I suspect the previous owner can probably point you to the problem (but will deny knowing anything about it).
  3. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    replace the 12 volt battery with a good quality one then reset the error codes and the lights should go out, while you have the battery out push out the rubber drain plug in the bottom of the car as sooner or later all these cars leak into that area.
    good luck
  4. JC91006
    16,674
    8,519
    resetting the car and getting rid of the lights, does not fix the existing problem.
  5. usnavystgc
    3,159
    990
    Tucson, AZ
    Yes, I agree with JC. Do not reset the car without reading the codes first. Then if they come back, you can read them again and check for consistency. There is really no way to know what the problem is without the codes.
  6. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    I too vote with the majority on this one. 12.3 volts is weak, but still should work. It sounds like there is a issue elsewhere that needs to be addressed first.
    I would get the offending system that is causing the abs light/red triangle etc. to come on fixed, then consider whether or not I want to invest in a new 12 volt. Based on age alone, it would not surprise me if you will need to work on the traction battery, but again the codes are what you should go by. Anything else is just a guess.
    Best of luck to you.
  7. JC91006
    16,674
    8,519
    I think you should first check to make sure all the recalls on the car are completed. If not, that could easily be the cause and it wouldn't cost a dime to fix.
  8. stockdaddy
    stockdaddy Member
    208
    56
    Missouri
    You reading the 12v battery under load such as with lights on?\
    Ya the previous owner could have known there was issue. You can get a code reader for far less that it would cost for a shop to read the codes.
  9. Salvage09
    38
    Pasadena CA
    ANSWER!!!
  10. JC91006
    16,674
    8,519
    12.3 volts is not that low where it would create problems for the Prius. Replacing the battery will not do anything
  11. andrewclaus
    andrewclaus Active Member
    993
    326
    Golden, CO
    I've been keeping a close eye on my aging 12V battery and have been seeing voltages as low as 11.9 no load, 11.7 accessory mode (no fan or lights), and haven't had a problem yet (I'm replacing the battery next week). I've heard here of voltages as low as the high tens and the system still boots up. 12.3V is a good day in my car.
  12. Mendel Leisk
    40,586
    11.9 volts is what I saw, after forgetting the driver's door open for about 18 hours. I'd hazard a guess a battery at that voltage for some time would be deteriorating rapidly.
