Is +12V Supplied to Prius Antenna?
Discussion in 'Gen 3 Prius Audio and Electronics' started by Rebound, Dec 5, 2011.
  1. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    I'm installing a rear-view camera and I need to supply power. A convenient spot appears to be at the antenna. Doesn't it receive 12V when the radio powers up? This should be perfect.
  2. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    The antenna is powered but it's powered by the radio. Unless you know that there is excess power available at the antenna, it might not be a good idea.
    The back-up light power circuit has excess power available.
  3. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    If in fact the antenna is powered, I am sure there would be enough power for the camera... it shouldn't draw very much.
  4. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    The signal amplifier is the component that is powered.
  5. Rebound
    3,964
    2,613
    Portland, OR
    Thank you, but I want a power supply that switches on with the ignition or radio, if possible. That way I can use the camera without being in Reverse, if possible. Plus, being lazy, perhaps the antenna location is easier to get to in this case.
  6. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    cproaudio might know how to set it up how you want and where to find power. I think he has his set up to be turned on whenever he wants.
  7. johalareewi
    johalareewi Member
    393
    44
    uk
    You can get power off the rear windscreen wiper motor.
    Have a look at the cheap ebay camera thread... Post 66 and 89...
    http://priuschat.com/forums/gen-iii...21-new-camera-install-cheap-ebay-cameras.html
  8. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
