Is '15 Inverter different than '10-'14? Different P/N?
Discussion in 'Gen 3 Prius Main Forum' started by Haschwalt, Aug 10, 2019.
  1. Haschwalt
    Haschwalt Member
    110
    31
    New York
    the '10-'14 have a 15 year extended warranty from date of first sale, whereas the '15 inverter doesn't get it. I saw one post of someone's '15 inverter dying. I couldn't find anything about whether or not the '15's inverter is different & haven't seen a thread about this before. Maybe someone on here knows.
  2. StarCaller
    StarCaller Senior Member
    1,244
    697
    Cedar Crest, NM, USA
    check it out man /
    why don't you just go to some toyota dealer website & search for both..../
  3. BZzap!
    BZzap! Senior Member
    1,607
    877
    Probably only firmware update on the 15.
  4. Haschwalt
    Haschwalt Member
    110
    31
    New York
    Apparently they changed the '15 inverter per Toyota expands Prius recall, reveals up to 20,000 hybrid inverters failed - Los Angeles Times where "The company agreed in 2014 to replace the inverters under an extended warranty coverage if they did fail, but chose not to replace all of the inverters with a newer design that was released at some point in 2014."
    Wonder if these late '14/15 inverters will work on say '10-'13.
  5. Vman455
    Vman455 Senior Member
    534
    551
    The Middle
    I just checked a couple of parts sites, and neither of them sell the inverter, or even list its part number. The only way to compare part numbers may be to physically look at a pre-2015 and 2015 inverter.
  6. dig4dirt
    dig4dirt MoonGlow
    1,150
    741
    Lancaster Co PA
    2014 Prius c
    Just looked at my 2015 persona manufactured 8/14
    Inverter asst w/converter
    and part number is G9200-47230
    Probably irrelevant by my 2014 C
    manf. 7/14 part number is G9200-52010
  7. Elektroingenieur
    2,515
    3,258
    Three Touring
    parts.toyota.com lists the service part numbers for model years 2010, 2011, 2012, 2013, 2014, and 2015 in Figure 84-31, HV Inverter; part name code G9200, INVERTER ASSEMBLY, WITH CONVERTER, by production year and month:
    G92A0-47030 (2009-04 to 2011-07)
    G92A0-47031 (2011-08 to 2011-12)
    G92A0-47040 (2011-12 to 2012-03)
    G9200-49025 (2012-03 to 2013-10)
    G9200-49065 (2013-10 to 2014-03)
    G9200-49075 (2014-04 to 2015-11)
    In other words, the service part number changed at least once every year.
    Remember that the parts catalog is just meant to tell you what part number to order as a replacement. It’s not the engineering bill of materials for the car, so it doesn’t list production part numbers, such as G9200-47230, kindly mentioned by @dig4dirt above, nor G9200-47140, G9200-47141, G9200-47180, and G9200-47181, mentioned in the J0V recall work instructions.
  8. Haschwalt
    Haschwalt Member
    110
    31
    New York
    can the '15 invert be used in the older ones?
  9. Vman455
    534
    551
    The Middle
    Yeah, I was just checking on the off chance they had them listed, but no dice.
  10. Mendel Leisk
    38,653
    Exactly. I usually go to McGeorge Toyota Parts, plug in different model years, search for parts. That's how I figured out the pistons/rings switch over, for another example.
    The one hiccup: there might be a supersceded part number for the earlier model year? The intake manifold is like that I think.
  11. NewHybridOwner
    NewHybridOwner Active Member
    607
    282
    W. Michigan
    Best to plug in the VIN if the Web site allows: I've encountered a situation (not with a Toyota) where an engineering change occurred during the model year and the parts were not interchangeable because the mating part had changed too.
  12. Elektroingenieur
    2,515
    3,258
    Three Touring
    It’s not a published supersession: G92A0-47030, G92A0-47031, and G92A0-47040 have all been replaced by G9200-49025, but that’s as far as it goes. The J0V instructions just say to “order by VIN,” which suggests to me that the dealer has to get Toyota involved if the inverter assembly must be replaced.
    Agreed, but that doesn’t always work—even parts.toyota.com doesn’t seem to implement the full “single part no. identification function” supported by the Toyota Electronic Parts Catalog database.
