Is 2016 gen 3 "after the fix" for head gasket issues?
Discussion in 'Prius v Main Forum' started by G Man v5, Sep 13, 2022.
  1. G Man v5
    G Man v5 Member
    158
    I know I've read this and have searched but couldn't come up with info. My 2012 pretty much died...270K and have the p0301 misfire. Mechanic put a scope in cylinder and says it appears to be cracked....
    Anyway, I have a line on a 2016v with 122k miles. Are these supposedly better???
    Thanks..
    49,492
    yes, mid 2014
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,976
    4,717
    Texas Hill Country
    A 2016 v wagon is still gen3. If you believe in Mendel's egr theory causing all things bad in a gen3, then you are hosed with a 2016 v. If you are more aligned with professional mechanics at Toyota and other wisemen of the internet, one might take solace in the fact the 2016 v has revised pistons and rings plus it was not part of the brake booster program.
    Any used car is worth a dealer pre-purchase inspection with particular focus on maintenance records, the engine and a thorough front to back review.
  4. Mendel Leisk
    38,727
    Better for piston rings, but same EGR, and still prone to head gasket failure, my 2 cents.
    Tim Jones and bisco like this.
  5. G Man v5
    G Man v5 Member
    158
    Thanks for the info. On a completely unrelated note or sort of related, I used a small bottle of k seal and it worked great.
  6. bisco
    49,492
    that should do it
  7. rjparker
    7,976
    4,717
    Texas Hill Country
    Sealer clearly means head gasket failure which will come back. Maybe with strange overheating symptoms.
    Tim Jones likes this.
  8. G Man v5
    G Man v5 Member
    158
    How long can it last? I am still losing coolant, but it is running fine.
  9. rjparker
    7,976
    4,717
    Texas Hill Country
    Not much longer if you are still losing coolant
  10. g22
    g22 New Member
    Boston
    What preventative maintenance should be done religiously to prevent blown head gaskets and gaining brake booster/accumulators?
  11. Mendel Leisk
    38,727
    For the brake booster I’m not sure anything much; Toyota sold a failure prone product. Tri-yearly brake fluid replacement “might” help.
    for the head gasket, I’m betting on 50k carbon clean outs, for the full path of the EGR circuit, that’s all the EGR components and the intake manifold.
  12. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    Don't buy a Gen 3................
