Is 50/50 a possibility?
Discussion in 'Prime Main Forum (2017-2022)' started by Hybrid Hound, Sep 2, 2022.
  1. Hybrid Hound
    Hybrid Hound Junior Member
    35
    17
    South West Florida
    As an owner of a low mile 2015 Prius 3 (NON-PRIME) that has been a very good car for us, I am not chomping at the bit to trade, but I do have a question for you Prime owners. This question is partly based on our good experience with a 2013 Volt a few years ago. I would go 48-50 electric miles regularly (here in balmy, flat Florida), and get 35-40 MPG on Dino after the electrons dissipated. The car would charge to 90% and then stop, and would fall to about 40% after the charge was gone. Here is my question...Do any of you foresee a time when the Prius Prime would go 50 miles on a charge, then deliver 50 MPG on Dino Fuel? That would be worth waiting for!
  2. drash
    drash Senior Member
    2,483
    1,256
    Upstate NY
    If Toyota does one thing, it is they reuse the same battery pack over and over. For the Prius PHEV models they've doubled their packs from 4.4 kWh for the Prius Plug-in to 8.8 kWh in the Prius Prime. If they double it again for the next generation you'll get 17.6 kWh which is very close to the 18.1 kWh battery packs they use today in the rest of their PHEVs. It might be possible to see the same 18.1kWh pack we see in all Plug-ins. That battery appears in the RAV4 Prime, NX 450h+ and the new RX 450h+. If they do that, it might be possible we'll see the same newly developed 1.5L 3-cylinder engine as seen in the Yaris Cross GR Sport (which is a hybrid BTW) as a base engine. But a lot of the chatter says it'll go to the 2.0L because it's Toyota's most efficient. We'll find out more as we get to next spring.
    Salamander_King likes this.
  3. MalachyNG
    MalachyNG Active Member
    300
    221
    Northern NY
    2022 Prius Prime
    I've gotten close to 40 miles but 50 would be a stretch without redesigned battery pack. If they build it from the ground up they could definitely fit more battery below the rear hatch. It's s few inches taller than a regular Prius because they left the floor with the spare tire area the same but didn't fill the void with the battery pack. Some more kwh's it'd definitely make it 50 miles.
    The Prime already gets better than 50mpg after the EV range is depleted. In fact I find it gets better mileage on hybrid mode than the 2016 Prius it replaced. Low to mid 60s according to the meters so definitely upper 50s real world.
    jerrymildred likes this.
  4. dtsexpert
    dtsexpert Member
    167
    San Francisco
    dont know the amswer for the increasing in EV range, but in hybrid you easilly get 60mpg
  5. RovinRon
    RovinRon Junior Member
    33
    22
    Federal Way WA./Sun City AZ.
    We have a 2017 Prime for our winter residence in West Valley of Phoenix. For our type of driving there it has been perfect. Runs on the traction battery for up to 35-40 miles, maybe more if under 35 mph, just under if freeway speeds. Had 1200 miles on trip odometer, filled up with 5 gallons of gas!! Not complaining a bit!!
    mikey_t and douglasjre like this.
  6. Salamander_King
    Salamander_King Senior Member
    10,975
    8,867
    New England
    For low to mid-speed (35-50mph) short trips, I regularly get 35 miles of EV range from a full charge during warmer seasons. This is 10 miles more than the EPA-rated 25 miles range. The range suffers a lot in the winter months down to 18 miles on some very cold days such that my yearly average EV range is around 30 miles or 5 miles/kWh of efficiency for 6kWh of the usable traction battery (8.8kWh). On the other hand, as others have already pointed out, the HV efficiency of PP is already superb. In most driving conditions, I can easily beat the EPA-rated 54mpg. My overall average HV-only portion of efficiency is ~60mpg calculated.
    Based on the 30 miles average EV range I am getting now, in order to achieve 50 miles average EV range out of a PP, one would need to increase the size of the battery by about 45% to 12.8kWh. The Rav4Prime already has an 18.1 kWh battery on it. I am sure if Toyota redesigns the PP specific to PHEV, they can come up with a space to put additional battery packs.
    The question is for what cost? Are there any potential buyers willing to pay the increased cost on a PHEV, especially if no tax credit can be applied? Hard to say in this crazy market. But for me, even if the All-New PP has increased EV range above 50miles, I would not be interested without incentives. After all, I got my 2021 PP Limited with a $35K MSRP for ~$23K after rebates and incentives. So, for an All-New PP with an increased EV range, the price tag of $25K or better must be met. Otherwise, I will just stick with the current PP and wait for a BEV price to come down.
  7. PT Guy
    PT Guy Senior Member
    1,085
    710
    Washington, the state
    With this battery technology it would take a larger, heavier, more expensive battery to get to 50 miles of EV operation. Of course, the added battery weight is somewhat self defeating. I already get about 60 mpg on the highway with my Prime; a heavier battery would hurt that, also. With new battery technology...wait and see.
  8. bisco
    49,489
    unlikely. they couldn't even figure out how to stuff the current battery in there.
    rav4 prime is a whole different enchilada.
    unless a miracle happens in battery energy density at some point, i don't see it. and if it does, we'll probably be on to bevs by then.
  9. Gokhan
    Gokhan Senior Member
    4,655
    1,866
    Paramount CA
    50 miles on a charge? Sure, you could get over 500 miles on a charge if you make a path spiraling down on a mountain, but for round-trip driving, don't expect over 35 miles in city and 30 miles on highway. The slower you drive, the higher the mileage will be, my record being 43 miles round-trip going about 25 mph. In more common driving speeds, you will get around 27–35 miles depending on your speed. Yes, the EPA range does underestimate the actual range of the Prius Prime.
  10. Trollbait
    11,560
    The Prius Prime very likely was designed for a battery the size of the one in the PiP. The designers had to scramble when the decision was made to fix that. The current battery, and it's packaging ended up being a rush job. Which is why it was done poorly.
    The use of air cooling increases the overall size of the pack in order to not have restrictions to the air flow inside. Go with liquid or refrigerant cooling, and the bulk can be cut from the pack. Don't make last minute changes, and the engineers can better pack the battery into the car. This is why the Rav4 Prime has a battery over twice the capacity of the PP's with little loss of space to it.
    The Rav4P has over 40 miles of range. PP with 50 should be doable with technology now.
    mikey_t likes this.
  11. douglasjre
    douglasjre Senior Member
    1,877
    653
    Orlando, FL
    Volt battery life can't be assimilated to Prime
  12. bisco
    49,489
    you can't sell that system in a prime, it's designed for carb credits
  13. Trollbait
    11,560
    I'm saying a 50EV mile PP can be made without a major battery advancement. Not whether Toyota will make one.
    If they did, it should only add $2000 to $3000 to the price.
  14. bisco
    49,489
    maybe, and i'm not conceding the point. idk if it can be done that cheaply. rav4prime is expensive.
    either way, the o/p wants to know if it is possible that toyota will do it, not that it can be done.
  15. Hybrid Hound
    35
    17
    South West Florida
    Thanks to all for the "Insight" (couldn't resist). I really did not know that in the real world the PP was getting that kind of gas mileage. What a car! Gives me a lot of room for thought. But, as one reply said..."at what cost?". Seems like we are always doing cost/benefit comparisons here...which is good for us lest we stray from our goal to save money while driving a well-made car. Thanks to all who commented! Slinking back now to the 3rd. Gen. Prius forum LOL!
    bisco and Salamander_King like this.
  16. GregersonIT
    GregersonIT Member
    172
    92
    Livermore
    2020 Prius Prime
    Yes, 2035 rules for california cars require that PHEV vehicles must go 50 miles on the charge before switching to gas. Also the rav4 prime already does about 50 miles on the charge.
  17. bisco
    49,489
    i would hope we're way beyond prius primes by 2035
  18. GregersonIT
    GregersonIT Member
    172
    92
    Livermore
    2020 Prius Prime
    I would expect that Toyota in order to get ahead of the game would likely bump up the existing prime to 50 miles by 2025.
  19. bisco
    49,489
    i don't think they can, at the right price point
  20. Trollbait
    11,560
    I think it will be more a question of their battery supply.
