Is a Level 2 charger really 100 percent better?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by davidbw, Apr 11, 2012.
  1. davidbw
    davidbw Member
    110
    29
    In front of my computer
    Normally when I charge my Prius at home it takes three hours, and when I initially plug it in, the Prius system estimates that it will take three hours to charge. And after charging it would say 13 miles.
    Several times I would try using a Chargepoint public charger. I thought it being a Level 2 charger that it would take 1 hour and a half to charge my Prius. However once the Prius is plugged in it says two to two and a half hours to charge, not an hour and a half. The Chargepoint charger itself would say it is delivering 2.4 to 2.6 kw; the Prius would say it is receiving 1.5 to 1.8 kw. I have yet to fully charge the Prius at a Chargepoint charger, but the Prius would say "8 miles" after a 90 minute charge.
    Is the Prius charging at a slower rate because I am charging immediately after arriving at the charger as opposed at home when I set the timer to start charging at 3 AM?
  2. pfile
    pfile Member
    319
    35
    bay area, ca
    i've never seen the prius pull more than 1.9KW (as shown on the car's display) while charging at L2. i've never taken care to start with a cold battery, though.
  3. CharlesH
    2,796
    1,163
    Roseville, CA
    Isn't the in-car display showing what is going into the battery, not what is coming in at the plug?
