Is a Lift for my gen 2 from the Toyota parts bin possible?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by turbo5spd-prius, Sep 28, 2023.
  1. turbo5spd-prius
    turbo5spd-prius Junior Member
    71
    United States
    Hello,
    Does anybody know if there's a U.S. market Toyota whose front struts and rear shocks could be installed on a Gen 2 to give it about 1 to 2 inches of added ground clearance? I know the Prius is midling size between the Corolla and Camry at least.
    Since I need to replace my struts and shocks, I'm hoping I can mod it and fix it in one move.
  2. douglasjre
    douglasjre Senior Member
    2,180
    718
    Null, NL
  3. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Direct fitment, currently unknown, but you might want to experiment with the forum search feature.
    This thread by @strawbrad could inspire you : Heavy Springs And Lift Upgrade | PriusChat
    Please let us know if you find something compatible.
  4. Jstampfl
    Jstampfl New Member
    25
    Mongolia
    2018 Aqua
    I
    CEIKA has adjustable coilovers with up to 4 inch lift. Direct easy install. I put a set on my 2018 Aqura.
    SFO likes this.
  5. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Though i've seen lifted gen2/3 prius images before, could you please post some images of your lifted 2018 Aqua.
  6. turbo5spd-prius
    71
    United States
    That's an interesting thread. Close to what I'm after but not quite, as there's no 1 for 1 match and you have to hack a bit to get it to work. I'll probably still bookmark it though.
    Thanks.
  7. turbo5spd-prius
    71
    United States
    Just looked at their website. I only found them for the Prius V. That said, that hardware is too nice/rich for my blood. :)
  8. turbo5spd-prius
    71
    United States
    Yeah, I've checked them out. Looks like good hardware. I was just hoping to get it done more cheaply (already need new basic parts) and simply (just swap out the parts, no extra hardware to deal with) with just standard parts from a different model. At the end of the day, that may be the best option though.
    Thanks.
  9. douglasjre
    2,180
    718
    Null, NL
    You lock your location in your profile so I don't know if I can help u
  10. turbo5spd-prius
    71
    United States
    Hey,
    I'm in the desert Southwest. I left the settings at defaults. Didn't even know there was a location display setting. Just trying to keep my hotrod on the road.
    That said, it may be a bit before I start messing with the suspension. I just tend to scan the horizon on things I anticipate having to work on. Recently had lots of stuff pop up and had to fix it with no such preparedness.
