Is a Prius right for me?
Discussion in 'Newbie Forum' started by commuter, Jan 9, 2012.
  1. commuter
    commuter Untitled
    16
    I'm shopping for a new daily driver/commuting car. My commute is a wide mix of highway, local roads, flat, hilly, stop-and-go, and occasionally bumper-to-bumper.
    Here it is in a nutshell, one-way:
    • 1.25 miles up a steady 5-10% grade
    • 2.25 miles along the plateau of the mountain
    • 1.25 miles down a steady 5-10% grade
    • 23 miles of freeway
    • 10 miles of stop-and-go and backroad mix
    Average speed is between 20-60mph, with occasional 5-15mph bursts depending on traffic volume.
    Then, take that one way commute and reverse it for the ride home.
    I am strongly considering the Prius for the fuel economy. Right now I am hammering my Subaru 76 miles a day, to the tune of 3 gallons of gas a day. That needs to stop!
    Can I reasonably expect to get near 50 MPG in a Prius acting as my commuting car? Still new to the technology of a hybrid, and uncertain about the needs of the system relating to the longer climbs and descents in my commute. Looking forward to a test drive and possible purchase.
    tia,
    commuter
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    I am guessing around near 50 in the summer w/o any special hypermiling techniques. Lower in the winter of course.
    What would be your max speed and for what distance?
    Welcome aboard by the way!
  3. fulltank
    fulltank New Member
    230
    38
    Arkansas
    It would be very hard to calculate based on what you've provided. It's still going to depend on HOW you drive within these different stretches. Not sure if you can get 50 but I'd be willing to bet you could at least get 45 with little effort. 50 is certainly possible but will take more effort on your part. The Prius is not a magical vehicle and requires work on our part.
    I'm sure you'd love the car and I'm sure it would get better MPGs than most all other cars on the market!!! Good Luck!!!
  4. ksstathead
    ksstathead Active Member
    1,244
    244
    Kansas
    You should meet or beat 50, unless you are aggressively into the gas pedal and brake pedal in that stop and go. Expect to fall just short of 60 mpg at a steady 60 mph on the flats.
    Learn to glide using the Hybrid System Indicator bar (just keep gas pedal slightly depressed to avoid regenerative braking the system assumes you want when foot off the gas completely). This way, when you need to slow or you are descending, you burn no gas and incur no waste from converting momentum back into stored electricity.
    But even without technique, you'll be fine.
    One caution, in deep snow, the plastic shields under the car can get damaged. It handles snow fine, until it drags bottom. Then the crusty stuff is a problem.
  5. fulltank
    fulltank New Member
    230
    38
    Arkansas
    Not trying to split hairs, but achieving 60 MPG really takes some work and I'd consider those type of results rare. Certainly obtainable but not common.
  6. ksstathead
    1,244
    244
    Kansas
    That is at cruising speed, not a full trip. The 60 at 60 result is a dream, I agree, but not by a wide margin.
  7. nerfer
    nerfer A young senior member
    2,507
    236
    28
    Chicagoland, IL, USA, Earth
    1. you go more than 5 miles each way
    2. you keep track of things to 2 decimal points
    => Yes, the Prius is right for you. :)
    I went from a Subaru Outback to a Prius nearly 6 years ago, and I haven't looked back! I doubled my mileage (halved my fuel bill) and I have a much shorter commute than you, meaning that for most of my drive the car is still warming up. For best mileage, read up on pulse & glide, but initially all you need to know is to accelerate normally and brake lightly (coast when possible).
  8. bisco
    49,543
    the only thing you said that concerns me is "i am hammering my subaru"
  9. JimboPalmer
    12,470
    6,868
    Greenwood MS USA
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    A Prius would work well for your commute. Mileage will vary depending mostly on how fast you drive for the highway leg. If you are one of those 80 mph commuters you will never see 50 mpg. If you are a 65 mph highway person you could easily see 50 mpg.
    Tom
  11. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    Yes. Those climbs will hurt mileage, but the extra distance will help make up for it, especially given the usual upper 60 speed limit. I don't like the sound of "burst", though. ;) It sounds like you could do better (whatever car you are in) if you could learn to follow the two golden hypermiling rules (anticipate and buffer) and try to flatten those mileage-killing "bursts" you wrote about.
  12. Gurple42
    Gurple42 New Member
    354
    Santa Monica, Ca.
    I live in LA and I just drive the car, keep up with traffic and don't worry about mileage, well I do a little, cause it's kinda fun but not much and my fuelly tells the tale, probably what you could reasonably expect.
  13. fuzzy1
    10,186
    Climbing should be no problem, though nothing will get good mpg during the actual climb. Descending slopes of less than about 2% grade are perfect, allowing the Prius to recover nearly all the fuel penalty of the climb.
    Your steeper descent may be long enough that the battery fills up with regenerated energy, so the engine and brakes must throw away the remaining regeneration potential, hurting overall mpg slightly. But compared to traditional cars, which throw away all the descending energy all the time, this factor will be small.
    Handled intelligently, the Prius can crush the Subaru here. (I still have a Subaru).
    Not likely in winter, though some still do. But come spring, your odds are good if the highway portion doesn't demand speeds above 65 mph.
    The earlier '60 at 60' comment refers to what the car ought to achieve on flat ground after the engine is fully warmed. The mandatory twice-daily warmup cycles, AC use, long steep descents, and higher speeds will inevitably drag down the average. But that still leaves plenty of room to get 50mpg, especially since you can spread out the warmup penalty (which hurts all cars except the true electrics) over a fairly long commute distance.
    Do read Jimbo's list of who won't have a good fit with a Prius.
  14. commuter
    commuter Untitled
    16
    45 would be an improvement over the 26-28 I get right now in the Foz.
    Will read up on it now, thanks! I like to think of myself as a well-informed shopper prior to stepping in the dealers door
    Only in the sense of my longer commute. The Foz wasnt meant for this. :eek:hwell:
    Thanks Jimbo. I'll get to reading shortly
    Not in the least. Typically I'm in the 55-65mph range on the highway during the commute. 35-45mph on the back roads including my ascent and descent. 25mph in the school zones. 5-15mph to 30-40mph in stop-and-go traffic
    'Burst' would be my descriptor in typical ebb and flow of traffic. Some spots are heavy, people backing up near bumper to bumper. Other spots are more free flowing.
    Thanks for the input everyone. My brain will be filling up with data and real world findings soon. Had a thought earlier of renting a Prius for a week to see how exactly one would stack up in my real world commute
    commuter
  15. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    50MPG is an EPA rating, and most drivers here are getting better then that.
    to OP: on my daily route I have a couple similar hills (a little bit shorter) and they don't kill MPG that much.. My MPG is in 58-60 in summer, 53-58 in winter. My wife gets ~5MPG less on the same route, driving slower (!). What you get will depend on how you drive and tire pressure.
    BTW I am not a hypermiller, I drive faster then avg. Trick is to look ahead and take action in advance good luck
  16. cyclopathic
    3,292
    547
    2014 Prius c
    you will probably see the best MPG on back roads and in traffic. My 34mi commute has the mixture of 3 and that is the case. Also MPG usually drops after the start due to warm up but starts going up after 5-8mi. You should do good your commute is long enough
  17. SlowTurd
    SlowTurd I LIKE PRIUS'S
    1,156
    333
    nj
    i live in bergen county NJ
    my commute is 8 miles to work 8 miles back through stop and go traffic with a few short runs at 35 mph during the commute.
    driving gingerly i can get, in summer, 51 ish.
    in winter,remember 10% ethanol and longer engine warm-ups, 43 mpg ish.
    driving to atlantic city and back, in summer - garden state parkway, i can get 60 mpg if i observe the speed limit and use cruise control.
    i also came from subaru outback sport, had 5 subarus in a row.
    getting 16-19 mpg sucked.
    awd is overrated. i only miss the subaru for 3-4 snow days out of 365 days in a year. they do plow the roads. if i want more traction i could get winter tires but, don't need them. as good as a subaru is you won't look back. if you really want/need an awd hybrid you could wait until their hybrid comes out for the 2013 model year. don't count on them doing it in time though. subaru "evolves" very slow.
  18. commuter
    commuter Untitled
    16
    Bought the car, and updated my profile here on PC. About to learn the ropes as I go. Thank you again to everyone for your thoughts.
  19. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Right on, congratulations. Enjoy the ride!
  20. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    Great news, welcome to the club! Hope we see lots of you around on PriusChat.
