Is a Transaxle fluid "flush" possible?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by DGH, Dec 18, 2018.
  1. DGH
    DGH Thread Terminator
    365
    94
    Wales, WI
    Went to dealer for transaxle fluid change.
    The bill was higher than previous changes, dealer justified it saying a flush was performed.
    Is a flush vs drain and fill even possible?
    Thanks,
    Dan
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    No. It is just drain and fill, no torque converter
    DGH likes this.
  3. audiodave
    audiodave Active Member
    800
    272
    US
    DGH likes this.
  4. DGH
    365
    94
    Wales, WI
    Thanks Jimbo,
    I have trusted this service writer but lately he has been acting odd. This seems to confirm my suspicions.
  5. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    Nothing to flush. Just a case with some gears and a couple electric motors. Dealer is apparently a crook.
    douglasjre, James1964 and DGH like this.
  6. Mendel Leisk
    42,049
    A flush would only be warranted if fluid contamination was suspected. The word "flush" appears maybe a dozen times in the 3rd gen Repair Manual, but invariably in the context of "level", for example: "push the seal in until it is flush with housing".
    In various Honda Shop Manuals I've had, a transmission flush is simply multiple fluid changes, with a drive around the block between changes. Again, it's recommended only if there's possible contamination.
  7. DGH
    365
    94
    Wales, WI
    It seems as if the service departments modus operandi has changed and not for the better.
    Thanks to all of you for your input!
    Raytheeagle and jerrymildred like this.
  8. Mendel Leisk
    42,049
    A new service manager, edicts from the franchise owner, and it can all go to hell.
  9. Mendel Leisk
    42,049
    What was the cost, btw? Transaxle drain-and-fill replaces about 90% and is on par with an oil change for difficulty. Should definitely not be over $100; $80 would be a fair price.
  10. El Dobro
    El Dobro A Member
    7,098
    3,275
    Sounds like it was a drain wallet, fill pockets.
    James1964, Raytheeagle and DGH like this.
  11. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    There are times when I don't think some service writers know, or care, which vehicle they are selling services for! :eek:
    DGH likes this.
  12. bisco
    52,536
    wallet flush
    DGH likes this.
  13. DGH
    365
    94
    Wales, WI
    The drain and fill price is 99.00, it used to be in the eighties.
    I will be paying a visit to the stealership to get some answers and money back.
    I did request a "change" on the overnight envelope.
    I will update you on my visit.
    Thanks to all,
    Dan
    #13 DGH, Dec 19, 2018
  14. padroo
    padroo Senior Member
    2,763
    2,253
    It's four quarts of oil. The price really doesn't seem bad. Actually it is easier than an oil change.
    Tim Jones likes this.
  15. Patrick Wong
    18,210
    6,514
    This doesn't sound bad, for dealership pricing. The last time I bought Toyota ATF WS was a few years ago but I recall the price at that time was $12 per quart. So if the oil cost $48, the labor and miscellaneous charge is $51 which, for dealer service, is a very fair price.
  16. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    Probably the dealer never touched it at that price. Dealer labor by me is $140 an hour.
  17. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,522
    2,543
    Taylors, SC
    Unfortunately, those who are most likely taken for a ride by the dealer are those individuals making $15-20 an hour in their own jobs and are willing to have a high school educated grease monkey to do it for $120 plus an hour.
    These are the same people who live from paycheck to paycheck and continue to complain about how they can't make ends meet.
  18. Fred Norris
    Fred Norris New Member
    CLT, NC
    Hi Dan,
    I didn't see it posted or I missed it? How many miles do you have on your Prius? I have a 09' Prius with 125,000 Miles maybe I should be thinking about Trans-axle change?
    Thanks for posting.
    Fred
  19. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    My dealer has done ATF drain and Fill twice for $90 and once for $110.
  20. Mendel Leisk
    42,049
    Four liter of the Toyota ATF WS, plus replacement washers for the fill/drain bolts, is roughly $40 at the parts counter, up here. The washers are ridiculously overpriced, at $3.80 (CDN) apiece, and the liters of fluid $9.14 apiece.
    I think they charge more than an oil change because of slightly higher supply cost (compared to bulk Toyota oil for sure, bottled aftermarket oil not so much), and just because it's unusual.
    The labour is roughly the same I think, especially with a full lift like the dealerships use. For me fussing around with floor jack and safety stands, getting the car raised and roughly level, it's maybe 15 minutes more work. And to fish a hose and funnel through from the top takes a few minutes. Also you want to go slow adding the last liter, until it starts coming back out.
    One thing I've read, for anyone else doing DIY: Toyota recommends not saving opened, partially used bottles of ATF WS, says something about air exposure being bad for it.
    #20 Mendel Leisk, Dec 19, 2018
