Is adding a second battery possible?
Discussion in 'Prius PHEV Plug-In Modifications' started by hyp3rmil3r, Dec 22, 2019.
  1. hyp3rmil3r
    hyp3rmil3r Member
    120
    95
    Northeast
    I see tons of traction batteries pulled from priuses for sale. Is it possible to wire one in conjunction with the one I already have in my car for double the battery capacity? It may sound naive but it would be awesome to boost the cars ev capabilities.
    I’m looking for an inexpensive alternative to the insanely price PHEV kits in favor for something more diy friendly.
  2. Leadfoot J. McCoalroller
    8,146
    7,645
    Pennsylvania
    2018 Prius c
    I would never call such a project impossible but it would be a very, very tall order as a DIY project.
    Three points:
    1. If you want to do this for extreme bragging points and cool-factor? I wish you the best- this would be big. Conversely, if you want to do this to save time, money or other resources, I urge you to stop now. You will rapidly exceed the affordability of PHEVs already available, to say nothing of those coming soon, all without ever matching their capability.
    2. Even doubling a Prius battery is not in the same zipcode of battery capacity as a typical PHEV. A Prius battery has about 1.3kWh capacity. Most storebought PHEVs these days offer 8kWh and up. So I would (not very seriously) suggest adding 3-5 more HV batteries as a starter goal. Obviously that vastly complicates things and yet still doesn't make much of a PHEV range-wise.
    3. The Prius Prime PHEV also includes a trick clutch between the combustion engine and the transaxle. This device allows the car to drive at highway speeds using electric power exclusively without also forcing the engine to spin in deadhead mode. Your car doesn't have this clutch, so your electric-only efficiency would suffer badly above roughly 40mph.
  3. Rmay635703
    Rmay635703 Senior Member
    2,669
    1,694
    Somewhere in Wisconsin
    2013 Chevy Volt
    Assuming you have a generic Prius NIMH you could just charge your battery up, reset the computer and on your commute the car would burn off some of the three to five EV miles you built up.
    understand this wears the battery out faster and may cause your car to freak out with CELs and other unenjoyable nonsense
    another method of mild range extension is modifying your 12 volt battery to be a 14 ish volt deep cycle, this shuts off the dcdc and drives 250-600 watts to your battery.
    take care not to exceed the cars maximum voltage while recharging (hard to do) and it does have a real effect on fuel economy similar to an alternator delete.
    in terms of having two NIMH batteries it’s a fire hazard so don’t bother.
    I recommend visiting ecomodder for actual real world mods that work to get better economy and not high hanging fruit that wastes time and money
    good luck
    Ryan
    #3 Rmay635703, Dec 23, 2019
    ScottHz likes this.
  4. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    Even if you added enough batteries to have useful range, you'd still have the speed and acceleration limitations that would make the car unusable for anything more than residential speeds. The MGs and inverter don't have enough power handling capability for highway speeds nor can the MGs spin fast enough because of the gearing and construction.
  5. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,801
    Undisclosed Location
    It's Hybrid Synergy Drive....don't mess with the Synergy.
    ScottHz, Marine Ray and jerrymildred like this.
  6. bisco
    52,390
    no
    Tim Jones likes this.
  7. hyp3rmil3r
    hyp3rmil3r Member
    120
    95
    Northeast
    Sounds like an ultimately unrealistic idea. I didn’t realize I’d need an excess of multiple batteries to make a difference. Also the lack of the clutch on my gen 2 mentioned on the prius prime would be a big issue. Really im not concerned about ev only mode, id just like the car to run in electric mode more often increasing MPGs.
    For example the prime runs in EV mode if you want, or in hybrid mode you achieve far more MPGs than a standard prius since the battery is much stronger. Then again I suppose it has a much much larger battery than just two gen 2 batteries. Thanks everyone.
    ScottHz likes this.
  8. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    THIS.
    All the computer systems expect to see a certain HV battery in place.
    Having one that is drastically different would likely cause DRASTIC results.
    So the answer is: NO. Not practical.
    ScottHz likes this.
  9. bisco
    52,390
    prime only achieves a small amount of mpg's over lift back, if you're not using wall power, and will not run in ev mode if the wall charge is used up.
    and yes, compared to lift back, prime battery is umongous
    ScottHz likes this.
  10. ice9
    ice9 Active Member
    581
    344
    norfolk va
    2018 Prius
    IF it was possible, and I won't say that it isn't, I would expect the only practical way of doing it would be to add a duplicate battery that could be electrically switched/swapped.
  11. Marine Ray
    Marine Ray Senior Member
    1,139
    947
    Sparks, NV
    You could alway get a Prius Prime :)
    douglasjre and fuzzy1 like this.
  12. hyp3rmil3r
    hyp3rmil3r Member
    120
    95
    Northeast
    Seems like there’s two responses here:
    1. DONT mess with the sanctity of your $875 224k mile prius its PERFECT!
    2. Hey it’s possible but probably not practical.
    I’d like to thank the type 2 responses for your measured input haha!
    In response to the type 1’s... guys my car is a junker. I’m happy to modify it and would like to if there are easy budget friendly modifications to increase mpgs. All I was asking is if there was an obvious easy way to add battery capacity. No need to get frazzled. I won’t be adding a battery after reading these posts, so rest assured knowing my precious synergy will remain untouched!
    ScottHz likes this.
  13. Leadfoot J. McCoalroller
    8,146
    7,645
    Pennsylvania
    2018 Prius c
    Think about that. How do you run in electric mode? By supplying power from a charged battery. How do you charge the battery? By running the engine on gasoline, or by harvesting momentum. How do you harvest the momentum? Get the car rolling, then apply regenerative brakes. How do you get the car rolling? <loop to beginning>
    All of the energy comes in through the gas filler, and then some of it gets recycled via the regen function. But only some, due to efficiency loss. Hypothetically you could make a Prius even more fuel efficient by eliminating the electric end of the hybrid powertrain and just coupling the engine to the wheels. Less weight to carry and no conversion losses in the electrics. Downside: it would be almost undrivable and hopelessly incompatible with traffic and drivers' expectations.
    In a sense, the real secret of Prius fuel efficiency is the tiny gas engine. It's too weak to power a Prius-sized car alone, but when combined with the electrics of the HSD, it gains driveability.
    MAX2, ScottHz and fuzzy1 like this.
  14. hyp3rmil3r
    hyp3rmil3r Member
    120
    95
    Northeast
    I would have charged the battery via grid much like a prime, really though I’m not looking for any more replies here. Mods can feel free to delete thanks.
  15. Rmay635703
    2,669
    1,694
    2013 Chevy Volt
    no worries
    nothing stops you from charging that battery for a small economy gain.
    many grid charge batteries to get life out of failing packs.
    and again
    ecomodder.com
    Darin, Neil B and Ben Nelson have all been there done that, start a thread there
  16. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    Some electrical issues. If the batteries are in parallel you need twice the current to charge them, you don't have it.
    If the batteries are in series you need twice the voltage to charge them, you don't have that, and it is unlikely you can get it.
    The other choice is PHEV one battery, so you have more current. At that point the cheapest way it to buy a PHEV.
    There were a whole flurry of kits to do this in 2004, but those companies are went broke paying out liability claims.
  17. sam spade 2
    7,035
    2,804
    2017 Prius c
    OR you need the same current for twice as long. ;)
    ALCRO and Isaac Zachary like this.
  18. Isaac Zachary
    Isaac Zachary Senior Member
    2,671
    1,381
    I've been tinkering with the idea, but in by no means think I would ever try it. From reading what others have done with the Prius, I do think it's doable.
    The thing for me is that when driving in the mountains it makes sense to have a bigger battery to adsorb the down hills and help push the car up the up hills. But I don't go over mountain passes that often to even come close to making such a project worth it. If I had to go over a pass every day, I'd probably get a PIP or Prime instead.
  19. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    The NIMH battery holds such little charge when they are 5+ years old. It would be flat by the time you leave your driveway
  20. sam spade 2
    7,035
    2,804
    2017 Prius c
    Total bunk.
    Where DID you get that idea ??
    We have lots of users on here who are still going strong after more than 10 years.
