Is alignment neccessary after rear shock replacement?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by cliffmark1, May 26, 2015.
  1. cliffmark1
    cliffmark1 Junior Member
    39
    us
    As the title suggests. I just replaced front shocks and got the car aligned. Now I feel the difference in front to rear and want to change the rear shocks out too. I seem to remember someone suggesting under normal circumstances the Prius rear setup never gets aligned. Is this true?
    Would I need to get another alignment if I replaced the rear shocks?
  2. JC91006
    16,482
    8,400
    no alignment is needed after rear shock replacement.
  3. cliffmark1
    39
    us
  4. Mendel Leisk
    38,728
    Basically because there's nothing adjustable on the rear. Unless you start putting beveled shims in. Behind the wheel bearing, I think.
  5. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    Look at the earlier alignment paperwork. How far out of specs are the rears? As Mendel pointed out, the only way to do a fix is via shims, or a NEW rear beam.
    Not all tire alignment places will do shims. Firestone Tire near me, I believe charges $250 (labor & shim).
    There is a thread about DIY rear shims here in Gen2.
