Is charging my PIP worth it?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Sidkane, Apr 21, 2012.
  1. Sidkane
    Sidkane New Member
    Bay Area
    I just bought my PIP and I am enjoying it for the most part, especially the electronics. What I'm trying to figure out is whether it's worth charging it versus just using it as a hybrid.
    1. I should say that the primary reason I bought it was to get a green HOV sticker here in California.
    2. I looked into purchasing a dedicated charging station but that was close to $2000 and for the 14 miles of EV range, it's not worth it and, in any event 2-3 hrs on a regular charge is not a big deal for me.
    3. But, according to the PG&E, the additional electricity used to charge the PIP every day would be several hundred dollars a month. Is that possible? If so how can that be cheaper than using gasoline?
  2. Sandiegomom
    Sandiegomom New Member
    109
    28
    San Diego
    It depends.
    What is your average monthly usage? What tier do you normally land in? Do you have a special rate schedule or TOU meter or anything out of the ordinary?
    Edited to add: in my case, if I charge once a day, it adds about 100 kWh to my bill. I'm in the lowest tier (and will bump a bit into the second some months) so I anticipate about $15/month extra for the PiP.
  3. crewdog
    crewdog Acting Ensign Prius Prime
    492
    388
    Woodstock, GA
    I've been using about 2.97 kw/hrs per charge at home on 120v.
    If you charge once/day at home, then a 30 days should be an extra 89.1 kilowatt hours of electric usage. That may put you in a different tier, depending on your electric provider, meter, etc.
    Hey, that extra 12.6 miles on EV adds up over time and will definitely help out your mpg even if you only charge once a day.
    I'm about to reach my 1000 miles on a tank goal...oh....so....close....
    just a few more EV trips to the liquor store......
  4. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    Several hundred a month? No way.. maybe if you were charging a Tesla Roadster everyday.. but certainly not a PiP..
    If you used even, say, 6kWh per day (approx 2 full charges daily), you'd only be looking at 180kWh per month. Unless you pay over $1 per kWh, there's no way you're into the "several hundred dollars a month" range. (Several hundred, to me, is something more than a "couple hundred", right? so something like $300+?)
    From what I've read here, PG&E rates seem close to SCE.. so even if you're in the highest tier, it would be some where in the neighborhood of $0.35 per kWh (IIRC). It would cost really close to the cost of gasoline (gas would need to be around $4.20 per gallon to be equal), assuming ~13 EVmiles per full charge and about 52MPG on gas.
    But several hundred dollars? I dont think so..although I suppose if you charged it to full, drove it empty, and repeated this process 4 times a day (so 8 full charges), you could get into the several hundred dollar range (about $252 per month at $0.35 per kWh).. although 8 full charges would be somewhere around 20 hours of charge time per day on its own..
    3 people like this.
  5. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    "3. But, according to the PG&E, the additional electricity used to charge the PIP every day would be several hundred dollars a month. Is that possible? If so how can that be cheaper than using gasoline?"
    Were you actually told this by a representative of PG&E? This doesn't seem likely.
    Here's a link to PG&E's rate info and a calculator you can use to estimate your costs to charge your PiP. It appears that there would be a one-time charge of $250 for a second meter, plus the costs for having a contractor upgrade your electical panel, if you decided to go that route. Otherwise, it looks like the rate structures are similar to what we in So Cal Edison territory have. SCE has a group of employees trained to answer questions regarding EV charging. I'm guessing PG&E does also.
    Select a Rate Option
  6. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    The only thing that our SDG&E employees seem trained to do is to submit rate increase proposals to the PUC…
  7. Rebound
    Rebound Senior Member
    3,996
    2,644
    Portland, OR
    I'll try to help. Electricity is sold in units called kilowatt hours, or kWh. Typical rates are ten to fifteen cents per kWh. Most utilities have tiered rate structures: The first few hundred kWh you use cost about ten cents each, the next 200 are twelve cents each, after that, they're maybe fifteen cents each. You have to check your bill to see.
    A full charge on a Prius is less than 3 kWh -- that's 30 to 45 cents. If you charge once a day, that's $9.00 to $13.00 per month. Some electric companies will give you a discount for charging at night, if they have SmartMeter technology.
    Where I live, in alameda, they don't have SmartMeters, so instead they offer a flat $15/month discount if I charge at night, on the honor system. I don't know how this would work out for a Tesla owner, but it's a net bill reduction for me -- I'm basically paid to have a Prius Plug-in. I'm sure they'll figure this out in time.
  8. Sidkane
    Sidkane New Member
    Bay Area
    Thanks everyone. The $15/mo makes more sense. I'd gotten my number from the calculator on the pge site. I must've input the numbers incorrectly, as I just redid it and it went to about $30/mo, which gets me about 300 to 400 miles of EV. That's pretty close to breakeven with gas prices.
    Thanks again!
  9. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
  10. Sidkane
    Sidkane New Member
    Bay Area
    Thanks for the volt link. Doesn't look like its a slam dunk that it's worth it there either.
  11. andyprius
    andyprius Senior Member
    2,212
    188
    Sacramento, California.
    This has all been pretty well answered. I assume this is your first Prius. You will find that plugging in to a normal 120V outlet works fine and most probably will look forward to driving, plugging in and posting on Priuschat.. There is also nothing wrong with your first reason, CAV sticker. THE Prius is more than just a car, it's a obsession! :welcome:
  12. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
  13. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    Yea, break-even because Prius PHV's electricity consumption is low. A heavier Volt that consume more electricity (360 Wh/mi) would cost you more than 50 MPG on gas.
  14. bilofsky
    bilofsky Privolting Member
    525
    177
    S.F. Bay Area, CA
    2014 Chevy Volt
    As a solar panel owner in PG&E territory (but a Marin Clean Energy customer), I can tell you that utility rates are anything but simple.
    My preliminary calculation is that my PIP will cost something like 2.7 cents per mile on electricity and 7.5 cents a mile on gas. But that's just the start.
    Because of my solar panels, I'm on a time of use rate. The real issue is whether charging will push me into a higher tier. This could double or triple the marginal cost (price for additional kWh's), or even more, making electric use more expensive than gas.
    During the summer, my solar panels will keep me in a lower tier. In the winter, I use more electricity for lighting and generate less, so am in a high tier for a couple of months even without charging the PIP. So I might just leave it unplugged in December and January.
    PG&E's E-9 rate used to permit charging in the wee hours for a few cents a kWh, but those rates have been raised substantially. So there's another thing - these days, rates keep changing, and usually upwards.
    My suggestion is to keep charging your PIP, get a Kill-A-Watt, track your monthly usage, and watch your utility bills. If you see numbers that make you think twice, then think about changing rate plans or unplugging your PIP.
    Me, I'm going to charge it, at least through the winter, and then look at the numbers.
    And you're right - a charging station doesn't make sense with the PIP.
  15. CharlesH
    2,797
    1,163
    Roseville, CA
    The current off-peak rate for PG&E's E-9A schedule is
    $0.03743 for Baseline,
    $0.05559 for 101-130% Baseline,
    $0.16 for 131-200% Baseline,
    $0.20 after that.
    I decided to give a it shot; I am locked in for a year, though.
  16. fjpod
    fjpod Member
    419
    72
    New York
    Certainly if you paid all that extra money for a Pip, you would want to charge it, but depending on what you pay per kilowatt hour, it may or may not be FINANCIALLY worth it. Where I live, in NYC, we pay about 26 cents per kilowatt hour, and by the way I figure it, charging a Pip is real close to my gasoline costs at 50 mpg on my regular Prius.
    So why would you charge it? For lower tailpipe emissions? Less foreign oil consumption? It's cool to drive electric?
  17. ursle
    ursle Gas miser
    1,049
    192
    NH
    As the PIP get's 42mpg in "hybrid" mode and 79+mpg in "charged" hybrid mode I'd think it would be a no "brainer" to double your gas mileage at a few pennies a day in electric costs, your drive is perfect for pure electric but even "charged" hybrid(79mpg) isn't bad.
    If I wasn't going to use the PIP feature I'd change to a hatchback and go with the 55+mpg anywhere anytime.
  18. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    :confused:
    the PiP's EPA MPG is actually 1 MPG higher than the no-plug Hatchback on the highway, 51/49 (versus 51/48 for the no-plug version).
