Is coolant reservoir under high pressure when hot?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ePRIU$, Apr 5, 2021.
  1. ePRIU$
    ePRIU$ Junior Member
    35
    There's no radiator cap in 2012 Prius 3, any coolants work go directly from the reservoir. My question is can I open the cap when coolant is hot? will it has high pressure like regular radiator with a cap? thanks.
  2. ChapmanF
    18,526
    Yes, it is under pressure. Unlike older cars with a "coolant recovery bottle" that attached at the radiator cap filler neck, Prius starting with Gen 3 has a "degas bottle" that is part of the circulating coolant system, so it is under pressure. Let it cool before opening the cap.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    And it very likely says that, right ON the cap itself. :)
  4. rjparker
    rjparker Tu Humilde Sirviente
    10,489
    6,575
    Texas Hill Country
    While I don't recommend it, I have slowly released the cap under pressure without steam or water erupting. The system does work nicely and always eliminates the air quickly after a coolant change.
  5. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    There's actually a bleeder nipple behind the cap to release the pressure and allow you to open the cap while the coolant is hot.
    ePRIU$ likes this.
