Is fuel stabilizer necessary?
Discussion in 'Prime Main Forum (2017-2022)' started by Kevin James, Feb 14, 2019.
  1. Kevin James
    Kevin James New Member
    2018 Prius Prime
    Since a tank of fuel could last over a month or even longer on a Prime. Is fuel stabilizer necessary?
  2. schja01
    schja01 Senior Member
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    A month? I personally figure I can go a year on a tank.
    Since gasoline is generally stable for a year I don't think I will use a stabilizer.
    If you go through a tank a month and stick with a reputable fuel (aka TopTier)
    I think you can avoid using it as well.
    I am sure there are a lot of opinions as to whether a stabilizer is safe in the Prius.
    I defer that to those more versed than I.
    PrimeDan and Mendel Leisk like this.
  3. Trollbait
    12,678
    Gasoline goes bad because more volatile fractions evaporate off, and the rest starts oxidizing. So octane drops, and gums can start forming. Which is why it isn't recommended to save gas for the lawnmower until next season.
    But that gas is usually stored in a cheap plastic can. The fuel tanks of modern cars are better sealed by far, which keeps the gas fresh. It won't keep forever, but the manufacturers of PHEVs have the system set up to burn off fuel it deems to be too old. So stablizer isn't needed.
    PrimeDan likes this.
  4. ETC(SS)
    7,349
  5. Tideland Prius
    16,615
    My tank lasted for 4-5 weeks in my Gen 3 without issues. It’ll be ok in the Prime if you’re refuelling every 2 months. The owner’s manual states that at least 20L of fresh fuel be added every 12 months. The car will remind you if you haven’t added any.
    I believe the Prime (and Gen 4) gas tank is pressurized. That should help keep the fuel fresher for longer, right?
  6. Kevin James
    2018 Prius Prime
  7. bisco
    52,380
    pip manual says 6 months is fine
  8. fuzzy1
    10,602
    Indirectly, that sounds right. I don't see how the pressurization itself helps, but the sealing necessary to keep it pressurized would certainly put a halt or sharp limit to the evaporation and oxidation that cause problems.
  9. El Dobro
    El Dobro A Member
    7,093
    3,271
    If you have to push a button and then wait for the car to tell you it's ready to refill, the tank is pressurized.
  10. benagi
    benagi Active Member
    525
    280
    Utah
    Has anyone seen a reminder to add gas? I drove mine for a year and never got a reminder.
  11. Tideland Prius
    16,615
    Well I'm thinking it'll reduce the vapour pressure difference to (hopefully) zero so evaporation isn't an issue. (I believe pressurization was to counteract evaporative emissions to get that AT-PZEV rating). So no evaporation means you're not losing components of fuel.
    KrPtNk likes this.
  12. Trollbait
    12,678
    An improperly fitting gas cap will cause the check engine light to come on for most cars. Even happened on my 2000 Ranger.
  13. fuzzy1
    10,602
    My basic understanding of the physics is that the liquid will continue evaporating until its partial pressure within the gas mixture above matches the vapor pressure of the liquid. (For a complex mixture such as gasoline, this makes for a complex situation, each chemical having its own separate balance point and evaporation rate.) Since the outside atmosphere contains very little of this stuff, its partial pressure there is near zero, so the only way to get this partial/vapor pressure match on top the liquid and halt further evaporation is to seal the container.
    Overall mixture pressure inside the container isn't relevant to the evaporation, except to prevent boiling. As long as it is well sealed, it could be under pressure, some minor vacuum, or neutral, they all can work. But container pressurization does allow the car to easily check for leak rate and report a problem to the driver.
    Maybe someone else can further illuminate the situation. Hopefully not with an spark of ignition ...
    I believe US rules have tightened since then, pushing for improved solutions. The Gen2 bladder was one of the attempted improvements.
    #13 fuzzy1, Feb 15, 2019
    Tideland Prius likes this.
  14. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,804
    2017 Prius c
    Where exactly do you get that "information" ? Reference please.
    And I suspect that almost nobody questions the safety of properly used stabilizer.
    The debate will be whether or not it is NEEDED.
    Personally I would be a bit nervous if the fuel isn't used up or "refreshed" withing 90 days.
    Certainly no problem in just 30 days.
  15. PT Guy
    PT Guy Senior Member
    1,085
    711
    Washington, the state
    How long gasoline remains good depends on several factors. The sealed gas tank is important. That keeps volatile fractions from evaporating off, and keeps atmospheric moisture away. The actual chemical composition of the gas we buy any specific day can vary. Another point is how good is good, and how bad is bad.
    Gasoline quality is lower after about 30 days. 90 days max without a stabilizer is probably a good rule of thumb, and one year with a stabilizer is a reasonable limit. And, it all depends--some engines are finicky about the quality of the fuel, and some will run with almost anything. How to Keep Good Gas From Going Bad This Winter 2018 in 3 Easy Steps
    So, if your Prime is running fine the way you're doing things, great. If you never need to buy gas, I'd use a stabilizer. It's cheap. The car will be ready for you for the day there's a power failure and you can't recharge. Getting the fuel system drained and cleaned is expensive. Or, periodically switch to HV, use some gasoline, and top it off with new gas.
  16. will the engineer
    will the engineer Active Member
    238
    119
    LA
    2019 Prius Prime
    Just fill up the amount you would end up using. Gas stations are abundant. Don't fill up over 50% just carrying extra weight TBH
  17. MNdriver
    MNdriver Senior Member
    549
    577
    I drove December 2017 to December 2018 on one tank a gas and the car never warned me to add fresh gas.
  18. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    The longest interval for gas fill-up on my PRIME has been 2 mo. I usually get the tank filled at least once a month, and in winter, when EV range is short and I don't charge as often, I refill every 2 weeks. No need for stabilizer for my PRIME. That said, I have kept 10% ethanol gas in my lawn mower over winter many, many times usually without any noticeable problem. I guess I am just lucky.
    #18 Salamander_King, Feb 21, 2019
  19. sam spade 2
    7,035
    2,804
    2017 Prius c
    But did you ever notice the gas engine running sometimes when it really didn't NEED to ?
    My guess is that it uses up some gas automatically and relies upon the driver to notice that it is running low.
    But then based on some of the posts here, that assumption might be a bit optimistic.;)
  20. Trollbait
    12,678
    Like most people, do you do nothing in terms of prepping the mower for winter?
    I'll run the fuel out, and then add some rubbing alcohol to the tank at the start of next season to get any water in the carb bowl out.
