Is it advisable to change transmission fluid at 140k?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by marooned, Aug 22, 2021.
  1. marooned
    marooned Junior Member
    Metro Detroit
    I bought 2010 Prius at 98k miles. At 110k I followed the maintenance suggested here on the forum....everything except the transmission fluid change. Just couldn't get those bolts off! I've been meaning to go to a shop and have them take the bolts off. But life got in the way. Now the car has 140k miles and I see that some youtube auto experts advise against changing fluid at such high mileage. What are the thoughts of the Priuschat experts? I still have all the supplies ready to go, and time to work on it. Just unsure if it'll cause more headaches.
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,918
    4,680
    Texas Hill Country
    Change the fluid. Conventional transmission advice does not apply inside a Prius transaxle that has 650v three phase and no conventional clutches. Also don't allow any other fluid except Toyota's special transaxle oil. Same reason, it is used as an insulating and cooling fluid.
  3. Colorado Boo
    Colorado Boo Active Member
    307
    202
    Monument, Colorado USA
    2021 Prius
    LE AWD-e
    Yep go ahead and drain and fill...no need to do any "flush". Since the bolts wouldn't come off that probably means it's never been done so expect the old fluid to be pretty black when it comes out.
    For folks who want to keep their cars a long time, the suggested change interval is every 6-year or 60,000 miles...whatever comes first.
    To get the old bolt off, spray a little penetrating oil all around the bolts and let it sit for an hour or so...then you can use a breaker bar. You can make one yourself with just a metal pipe that's about a foot to 18 inches long....just put it over your ratchet and turn using the bottom of the pipe. I've, also, seen at Harbor Freight extra long ratchets for 3/8 and 1/4 inch sockets that does the same thing.
    Best of luck! (Don't forget to buy a few crush washers!!)
  4. Mendel Leisk
    38,653
    My father-in-law was always harping about "you've gotta have the right tools". Case in point:
    #4 Mendel Leisk, Aug 22, 2021
  5. PriusCamper
    PriusCamper Senior Member
    11,065
    4,504
    Pacific Northwest, USA
    Yep... Primary difference between DIY and taking it to a shop is a good shop is constantly restocking commonly used parts and optimizing techniques with better tools.
  6. Mendel Leisk
    38,653
    It helps also, to have a higher-lift floor jack, and taller/beefier safety stands, to give you more elbow room to use a long-handled wrench. What's a strain with a regular handle socket wrench becomes easy, with another foot of leverage.
    Or use an impact. :)
  7. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    Open the fill bolt first.
    You’re up a creek if you open the drain bolt and then learn you can’t open the fill bolt.
  8. marooned
    Metro Detroit
    Drained and refilled! I ended up paying a shop to do it for me for $40. Kinda steep because I provided fluid/washers etc. but at least it is done now. phew. Guy said old fluid came out very black.
  9. Mendel Leisk
    38,653
    $40 is reasonable. (y)
  10. douglasjre
    douglasjre Senior Member
    1,858
    647
    Orlando, FL
    It's advisable to change it every 50,000. No need to be a fanatic about it. Next time you'll change it after this is at 200,000. Change the oil every 5,000. This makes it easy to remember when it was done last
  11. nicoj36
    nicoj36 Active Member
    495
    158
    Your Prius will love you lol.
  12. ColoradoBoo
    ColoradoBoo Senior Member
    952
    626
    Yep that's one of my favorite to break stubborn bolts! I just drain/filled the transmission on my daughters' 2012 Sienna and had to use it but need to be careful...when those bolts break free they are free, indeed, and hitting your knuckles on the concrete is not a good feeling!
    Her Sienna surprised me, it's a V-6 and I only got 2 quarts of transmission fluid out...so that's what I put in. My Tundra (V-8) got over 6 quarts out.
  13. Mendel Leisk
    38,653
    Geez, for the Sienna I might splurge for a short tech stream subscription: see what they say, regarding fluid volume and changing procedure. That said, I appreciate conventional automatic transmissions typically only drain about 50%.
  14. ColoradoBoo
    952
    626
    I think it was only a little lower than expected...on my Amsoil account it has a convenient capacities section and only lists 2.9 Qts for the Sienna. But it was pretty black, not sure when it was done last (she bought it used a few years ago) so I'll do another drain and fill next summer for her.
    FWIW, setting up an Amsoil account is free and lists our lubricants and fluids our vehicles need, capacities, and even torques for various drain/fill plugs.
