is it better for the Prius to go 8 miles to work instead of 4?
Discussion in 'Gen 3 Prius Technical Discussion' started by priustexasbob, Jan 19, 2011.
  1. priustexasbob
    priustexasbob Member
    356
    86
    arrakis
    2015 Prius c
    my office is 4 miles from the house, I can go a different direction and add an extra 4 miles to the trip.
    so the question: does it help the Prius to go the extra 4 miles? I'm not talking about the mpg but about what is best for the vehicle in general, expecially during the cooler weather. yanno, helping the engine, electrical system warmup.
  2. BrettS
    BrettS Active Member
    290
    136
    Orlando
    No, 8 miles vs 4 miles won't really make much of a difference. However, if you *only* take short 4 (or 8) mile trips, then you might want to take the car out for a longer trip (30 minutes maybe) every few weeks just to make sure the engine really gets warmed up every once in a while. If you take longer trips occasionally anyway, then you shouldn't have to do anything special.
  3. macman408
    macman408 Electron Guidance Counselor
    1,179
    366
    Agreed; if you take the 8-mile route, you're still running the car while cold for 4 miles as if you were going straight to work. But then, you're adding on an extra 4 miles of wear on top of it!
    The best thing to do is to bike - I bike 4 miles to work every day, my fiancée bikes 9 miles each way, and one of my coworkers bikes about 42 miles, albeit only 2 or 3 days a week (and I think only one way - he takes public transportation home). But not everybody is up for that sort of thing: so go ahead and take the 4 mile route. Your car will be no worse off. (You could consider adding grill blocking, as many hypermilers do, which will help it warm up faster - but it's probably not going to save you anything other than a little gas.)
  4. priustexasbob
    356
    86
    arrakis
    2015 Prius c
    thanks for the advice. I'll save the extra time and just take the 4 mile route.
  5. cit1991
    cit1991 New Member
    289
    95
    Tulsa, OK
    Drive it normally, just take out to Snook once in a while to get some chicken fried bacon. That'll warm up both of you.
  6. twittel
    twittel Senior Member
    1,605
    148
    Mt. Pleasant, SC
    (lol) Geez, couldn't you just work from home and use your Prius to take cool trips to San Antonio? IMO, it's an interesting question, at least with regard to how much traction battery charge/consumption occurs. I suppose that depends upon engine temp, braking, terrain, yadda, yadda... . My opinion is that it really doesn't matter.
    Happy Motoring,
    Tom
  7. Metalman
    Metalman Member
    107
    17
    Summer, KY; Winter FL
    A four mile trip will not be good for the oil. It will need to be changed quite often, unless you run the vehicle enough other times during the week to fully heat up the oil and boil off the moisture.
  8. BrettS
    290
    136
    Orlando
    That's what I was thinking with my above advice... however, I don't think that adding another 4 miles will really help much. Even 8 mile trips aren't going to be great for the oil. Ideally the OP will supplement his 4 mile commute with somewhat longer trips occasionally.
  9. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    2,996
    Fort Lee, NJ
    Find a 2 mile route. ;)
  10. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    I would walk! Good exercise and save a ton of money. Short trips a car killers!!! H
  11. priustexasbob
    356
    86
    arrakis
    2015 Prius c
    LOL wow you hmust have been in the b/cs area. Yep Soldulak's chicken fired bacon warms the heart and hardens the arteries
    I'd kill to work from home andio go to SA monthly to visit my sister.
    I would ride my bike, however the last mile would be on a two lane road with a 60 mph speed limit, no shoulder and a 4 foot drop off to the ditch. People in this city don't respect bicycles. :mad:
  12. ETC(SS)
    6,547
    You might be over thinkiing this just a bit.
    Granted.... College Station isn't as warm as the Gulf South, but you're hardly up in the frozen North.
    My ICE usually shuts down before I've gotten to the 4-mile mark, and I don't 'pre warm' the car when the temps go down into the 30s, which tells me that your car might also reach normal operating temps before you arrive at work.
    Either way, if you're logging that few miles a week, then your warranty will reach the 5-year mark long before you get 60,000 miles on the odometer, so your basic warranty will cover you for any problems that (won't) arise from this diving pattern. If you're like most folks, the "change owner" light will illuminate before you've reached the 5-year mark.
    If not....and if you're really really REALLY worried about it...get an extended warranty, but seriously. I'd put the giveacrap switch back to the '"don't" position, and enjoy the fact that your monthly fuel bill is so low.
    2 people like this.
