Is it me or my heater?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Reetz, Oct 26, 2013.
  1. Reetz
    Reetz Junior Member
    36
    Seattle
    I have a 2013 Prius 4. I'm not sure if there is a problem or not but the heater just seems to blow the same temperature of air no matter how high I set the temperature. The air feels lukewarm. I was driving 60 miles yesterday with the temperature set at 76. I had on a long sleeve shirt and polar fleece jacket and it never got to where I was really warm. Outside temp was about 50. Any thoughts?
    52,396
    it's your heater, should get plenty warm. try running manual and auto?
  3. El Dobro
    El Dobro A Member
    7,093
    3,271
    Sounds like just a setting. On longer trips, I have to turn the temp down.
  4. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Bring it to the dealer it is covered under warranty
  5. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Just remember moving air -feels- colder that it actually is. I find running the set temperature a little higher than I would set my house to works well. Remember in the car you have radiative energy loss through the windows from your body. Also remember the sensor is not where you are so the temperature where you are in the car may be different than what the sensor reads. Try turning the temperature up before you start complaining to the dealer. I run Pearl S at 24C in the winter and 22C in the summer.
  6. adamace1
    adamace1 Senior Member
    1,403
    193
    Charlotte, NC
    76 would feel luke warm. It will blow 76 deg air out at you. If you want it warmer raise it up, or go all the way until it says hi and it should feel very warm.
  7. 04priusnow
    04priusnow Active Member
    345
    201
    At 76 I would be sweating... I never go above 65 and that's only to defrost windows in the morning..
  8. Reetz
    Reetz Junior Member
    36
    Seattle
    Thats what I'm thinking. You want the inside air temp to be 76, the air coming out should be really warm until you get tot that temp. If I set my Audi heater to 76 in about 10 minutes I'd be dripping wet.
  9. wjtracy
    wjtracy Senior Member
    11,372
    3,608
    Northern VA (NoVA)
    ...check your coolant level.
  10. tach18k
    tach18k Member
    406
    38
    SoCal Beach Area
    One thing to look at is outside air temp, I run my car at 70 all the time and recirc the air. there needs to be al least a 10 degree difference bewteen outside and the inside settings. I need outside air to be below 60 before it starts to even heat. Again I am in manual mode with AC on. If I need heat when it is 65 outside, then I need to set it at 75 or higher. I can also just hit the defroster and I get hot air, but it is from the outside, nasty here in LA. I can turn the AC off and set the temp 10 deg higer and it heats.
  11. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    I agree that you have a problem with the heater or the coolant system. You should get plenty of warm air in auto with the temp set at 72 degrees or so, 76 should be quite warm. It's still under warranty take it back to a dealer and get it fixed. As Wjtracy suggests check the coolant level before you drive it.
