Is it my water pump going bad or is it my headgasket thats bad
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bootsncatsmeow, Nov 12, 2019.
  1. bootsncatsmeow
    bootsncatsmeow New Member
    Rancho Cucamonga
    I have a 2011 Toyota Prius with 222k miles. Its been running great however I've noticed a couple months ago that the coolant and the inverter reservoir was low. I topped it with 50/50 pre mix from my local Toyota dealer and the level did not go down. I have been checking my coolant level and oil level weekly and my coolant level did not go down and there was no coolant in the oil. However when I checked it last week the coolant level was low. I topped it off and checked it again today and it was low again. Wondering if its possible its the water pump going bad or if I do indeed have a bad head gasket and if anyone has any recommendations on where to get it fixed in Southern California.
    I got a quote from Hybrid 911 and plan on visiting them tomorrow to confirm however they wanted 2700 to put a motor in it and I'm not sure I want to put another 2700 into the car after putting a hybrid battery last year. The last thing I want is to put a motor in it and then have transmission issues.
    51,157
    welcome!
    still no coolant in the oil?
    are you checking underneath for leaks?
    any white smoke?
    i probably wouldn't bother with an engine either, although, thats a pretty decent price.
    trannies are pretty solid, brake actuator isn't though.
    maybe sell it for parts, the battery is valuable, as you know.
    mikey_t and PriusGuy32 like this.
  3. bootsncatsmeow
    Rancho Cucamonga
    No coolant in the oil and no white smoke.
    I've looked underneath for leaks but haven't spotted any.
    And thats what I was thinking if I do have to get a new motor for it maybe just try selling it for parts instead. It does have some cosmetic damage to.
    I'm also curious as to why it seems like to fix the head gasket on the Prius seems to cost more than regular vehicle. I got the head gasket fixed on a 2000 Tacoma I used to have for 1500.
  4. tankyuong
    tankyuong Senior Member
    1,555
    661
    Central MO
    I’d say bad head gasket,I’d replace the motor, cheaper than another car
    mikey_t likes this.
  5. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    I'd say read the OP again...…...
    I'm going to guess he meant to say "the coolant in the inverter reservoir was low" (????)
    If so, that has nothing to do with the head gasket or anything else related to the ICE.
    Inverter reservoir...………………= inverter cooling loop, not ICE coolant loop.
    Someone's going to charge you $2700, telling you they're going to replace the engine and then just tighten a hose clamp or replace a hose under the inverter.
    #5 TMR-JWAP, Nov 12, 2019
    mikey_t likes this.
  6. bisco
    51,157
    if thats the case, its a whole nuther discussion. i took the 'and' literally, or read incorrectly
  7. bootsncatsmeow
    Rancho Cucamonga
    I type that wrong. Both the coolant reservoir and the inverter coolant was low. The inverter coolant hasn’t gone down since I topped it off just the coolant reservoir.
  8. TMR-JWAP
    6,404
    6,080
    Columbia, SC
    Back to the drawing board for me...………….
