Is it necessary to replace faulty instrument cluster assembly?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Tim1, Feb 19, 2025.
  1. Tim1
    Tim1 New Member
    Virginia
    Occasionally when we start up our 2007 Prius, none of the instrument lights come on the dash. We had this checked out at the dealer and they are going to charge over $800 to replace the cluster assembly. I don't want to pay this much, and I wonder if there is any reason this must be replaced for the car to operate. We've been living with this intermittency for over 2 years now and, while a nuisance, hasn't caused any problems with the car's operation that we are aware of. Aside from allowing the driver to see speed, gas tank level, odometer, etc, is there any other reason that the cluster assembly would need to be replaced for the car to function? If not, I will probably opt to just keep living with the occasional blackouts.
  2. Brian1954
    Brian1954 Senior Member
    1,699
    663
    South Central PA, USA
    MAX2 likes this.
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,939
    1,900
    NJ-USA
    Well, when the dash (Combination Meter) does not work, that usually means that none of the warning lights can function. So you won't know if some system has a fault (or that you left the parking brake partially on).
    As things "get worse", the car may not turn on or off correctly (the computer or ecu in the CM is necessary for that).
    I don't know the rules where you live, but here in New Jersey a car will fail state emissions inspection if the odometer is inoperative.
    Brian1954 likes this.
  4. MAX2
    MAX2 Senior Member
    1,436
    482
    101
    Third planet from the Sun
    How do you determine the speed? By eye?
    What is the fine for not observing the established speed?
  5. MCCOHENS
    MCCOHENS Active Member
    252
    101
    Chalfont, PA
    Smartphones can be loaded with an app to show MPH and maybe even miles per trip.
