Is it normal to always have to use the parking brake?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by 2008PriusGirl, Dec 13, 2011.
  1. 2008PriusGirl
    2008PriusGirl New Member
    Arlington, VA
    Hi Everyone,
    I have a 2008 Prius that I bought used. (I know little about cars and I can't even tell you what model it is or what options package I have.) My question is about the parking brake. I always have to use it or else the car rolls -- similar to a manual transmission. Is this normal and does it have to do with the hybrid nature of the car? I wouldn't have a problem with always having to use the parking brake but it could be a safety issue when someone borrows my car or a valet parks it. I'll go get it fixed if it needs to be fixed -- I just don't know!
    Thanks in advance for any responses!
  2. El Dobro
    El Dobro A Member
    6,985
    3,218
    I use the parking brake in any car I drive. It helps take the stress off the pawl that's used in the trans when you put it in Park.
  3. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    I don't always use the park brake! You can use the park button before turning the engine off! My G2 goes into park when I stop the engine. It does not roll away! Hal
  4. uart
    uart Senior Member
    4,215
    1,201
    Australia
    No, it's not normal for the car to roll in park. It is normal for it to move a small amount as it takes up the slack in the parking pawl, but if yours continues to roll then there is a serious problem with the park mechanism
  5. 2008PriusGirl
    Arlington, VA
    Thanks so much, Everyone.
    So it sounds like I might have a problem with my transmission's parking pawl? Perhaps that isn't working? Is that how I put it to the service department?
  6. 2008PriusGirl
    Arlington, VA
    By serious, do you mean expensive? Yikes!
  7. Gurple42
    Gurple42 New Member
    354
    Santa Monica, Ca.
    Leave the car running, put it in park (on a hill), take your foot off the brake. If it rolls more than a foot or two, you got a problem, take it to the dealer. If it just rocks a few inches and stops, it is normal.
  8. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Yep. Agreed completely.
    The amount of roll back/forward on the Prius is higher than that of all automatic transmission cars I've owned or driven often. My salesman even pointed that out to me when I picked up my Prius (which I bought new). So, I always apply the parking brake.
  9. saechaka
    saechaka Member
    225
    Read this post by TomWu, it works. http://priuschat.com/forums/gen-iii...ion/84934-roll-after-putting-into-park-2.html
  10. 2008PriusGirl
    Arlington, VA
    I will try this. Thanks!
  11. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    As others have said, the car rolling more than a tiny of rocking when parked is not normal. While I have no clue what the cause is I'd at least have it looked at by a mechanic just to be sure that driving it will not cause more damage.
  12. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    It should not roll 2 feet, not even a full 1 foot, IMO. You'll feel it rock a few inches until the parking pawl engages, but not more than that. OP, you should clarify what you mean by "rolling". Some rocking and slight rolling of a few inches is completely normal.
  13. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    To answer the original question, it is a good practice to always use the parking brake after shutdown, because it helps exercise the rear drum brakes, as well as providing an extra layer of safety, especially on a slope.
    If the engine is stopped and the car is in park, then it may roll several inches when the generator turns it on, because a small amount of torque is transferred to the wheels in that process. If in Drive, then the car will move without throttle, because it mimics automatic transmission creep. If the car is in Park, whether on or off, in a flat parking lot with parking brake off, get out and push the car forward. It should travel less than a foot, and stop with an audible click. Make sure there is a curb or something not too far ahead, in case the pawl is broken and you can't stop it.
  14. 2008PriusGirl
    Arlington, VA
    It is definitely more than a few inches.
  15. 2008PriusGirl
    Arlington, VA
    I'd be a little nervous to try this!
    I will try it on a hill though and see how far it rolls w/o the parking brake on. I think I know the answer -- it will go fast and far.
  16. bisco
    49,701
    sounds like you better take it to the dealer before it runs away on you! sounds like the parking pawl is not engaging properly.
  17. seilerts
    3,326
    1,512
    38
    Santa Fe, NM
    Make sure you have the car in Ready! You'll need the power brakes to stop.
  18. a_gray_prius
    2,927
    782
    IL
    +10000000 I'd bring the car to the dealer ASAP. I rarely use the parking brake, but then I live in the flat-as-a-pancake midwest.
  19. edthefox5
    edthefox5 Senior Member
    10,096
    4,809
    Clearwater, Florida
    Ouch that's going to be expensive if the pawl is messed up. Whats the deal on the car?
    How long have you owned it? Was it a rebuilt title? What did you pay for it?
    Carfax it?
    Take it to the dealer and pay the $125 inspection fee. Don't pay a dime more till you post back here exactly what the dealer says verbatim off the written report.
    We will help you. Do not let the dealer talk you into a ridiculous repair bill
    about how many things are wrong with the car. Tell them you must consult with the husband before anything is done. Because a woman at a Toyota dealer service depot with an expensive problem is going to be taken for a ride.
    And btw, if its truly broken if it was me I would be happy to just use the parking brake for the rest of its life because that's an expensive repair labor wise.
    Keep that in the back of your mind. The only reason the parking brake pawl exists is so you don't have to apply the parking brake manually.
    Which is not that hard really is it? To save $ 4500.
  20. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    It could be as simple as a bad connection or blown fuse. It doesn't have to be expensive.
    Tom
